Question about Hotpoint WMA32 Front Load Washer
Wma32 Prewash light is flashing when controller is on rinse /spin .The machine stop running . but if you press and hold down the start button then change selction from rinse/spin to just spin you can get the machine to spin but no r
  • AnnieP394 Aug 27, 2008
    My WMA32 has only just started doing this. We have recently moved house and I know it doesn't like being moved and can be a bit temperamental for a while afterwards. Whatever cycle you put it on after the first fill, the prewash light comes on and flashes, the cycle stops and you have to press start for it to continue. It then goes on to wash, finishes that and then prewash light comes on etc etc. I can't put the machine on and go to work expecting the washing to be done when I return. Any ideas how to solve this please?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
Test Program Control
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer says the control is locked
My dear friend this is an very common problem people do face with.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 13, 2010 | Whirlpool WFW9600T Front Load Stacked...
Hi I have a whirlpool duet front load washer (GHW9100lW1) and the status is stuck on CONTROL LOCKED and i can't change it and the machine is no longer working.
DIAGNOSTIC TEST
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
display.
Dec 17, 2008 | Whirlpool Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WMA32 Front Load Washer Logo
107 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
