Error code C0070 - Office Equipment & Supplies
  • zahir0505 Mar 18, 2009
    I install the toner in the machine, then turn on to star making copies, but after 25 copies the code c0070 appears and some smell like burn into the machine...
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Check where the toner motor is there is a white plastic piece in the toner section that the motor goes into make sure that there is nothin wrong with it. it could stop the toner from turning and that could cause the code.
Motor could be bad or home position sensor could be dirty.
Also make sure it is not a generic toner, some people have had problems in the past with generic toner bottles, also if you have had the back cover off the machine make sure the sensor on the bottom left hand side is actuated.good luck
Posted on Jul 31, 2008
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Code error c0070, Minolta EP2050 Copier
C0070 means that your toner bottle is not rotating properly. First thing is to remove the toner bottle from the machine. Close the front door and let the machine run. This may take several minutes maybe even 10. If the code does not come back and once the machine has stopped then re-install the cartridge and let the machine add toner. If no code comes back you are fine. If it comes back after re-installing the cartridge you have a small plastic drive coupler in the hopper that has cracked or there is toner on the rotation sensor. Kind of a common problem on these models. If this happens just reply with a comment and I will point you to the parts you might need.
Most of the time tho this code is a result of an improperly installed cartridge or a cartridge from the wrong model. Should be 201A toner.
Good Luck
Jan 02, 2010 | Office Equipment & Supplies
Panasonic fp7781 error code c0070
Re install toner after shaking it up and reset main power
Oct 13, 2009 | Panasonic Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Hi eerror c0070
Toner moter drive fault. Bottle been put in wrong position. now jammed up machine. remove and turn machine off/on may work. If not have to reset error code in trouble mode. not a problem but engineer needed to do it.
Jan 25, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
52 people viewed this question
jasbo
jasbo
