Canon mv800i fault
Hi Ekse
The model canon camcorder is MV800i , the cassette is a TDK mini dv 60.
The loading mechanism will operate correctly with no tape installed but as soon as the mentioned tape is installed it wont even allow the tape to lower into the camcorder and after 5 seconds reopens and the lcd display says "remove the cassette".The camcorder is plugged into the power adapter and shows full charge, so low power is not the problem.
  • sublingual May 09, 2009
    Although you are an apprentice, this was a good solution.
    Some other bozo who considers himself a guru, gave the lamest answer I have seen on the net regarding this one.
    Thanks for passing it on, I think this is a logical solution.Will give it a go and get back to you
OK after searching the net to fix this problem and no one having the answer I decided to fix it my self.
My Canon MV 800i cam had the same fault to I took it to bits. Inside there’s the cams main board that has loads of ribbon cable connecting on to it from its bits like lens, power supply, viewfinder , cassette deek. I unplugged all of these and removed its main board and cleaned all the ribbon cables connecting end with isopropyl alcohol, you can use most electrical cleaners should do the some trick. Then just reassembled the cam and tested all fixed
Give that a go and see how you get on
Posted on Sep 22, 2008
My tape (tdk mini dv 60) was damaged by my sony camcorder. i need help fixing it. it's twisted inside the cassette. is there a way to untwist and splice the damaged part out?
Well if it's not personnal? I would send it to a camera store and have them repair it. If it is personnal? I would set time aside and dismantle it remembering how it goes back together.
Jan 06, 2011 | TDK DVM60 Mini DV Tape
My Canon Elura 60 is not working properly. The cassette will not load. I tried to change the power source to DC from battery, but it didn't solve the problem. The cassette tray loads fine without the...
Unfortunately, you will need to have your camcorder repaired. Inside of your mechanism there are several different components that can go bad and cause this problem. You might have a bad capstan motor or a bad gear. If you hear something spinning like crazy when you try and put a tape in, you have a issue with your capstan. Hope this info has helped you.
www.austintelstarservices.com
Sep 03, 2010 | Canon Elura 60 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Canon mv 800, camera does not accept tape cassette.
ok what you do is take the batery pack out and hit the camera there/
if it dont work try again
Dec 30, 2008 | Canon MV800i Mini DV Digital Camcorder
Camera will not load the tape, it ejects it immediately
if that is on warranty, send it back to the store where you bought it. they will repair that and do something with your camcorder.
CHARCOIS
Aug 20, 2008 | Canon MV800i Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Computers & Internet Logo
278 people viewed this question
David Payne
David Payne
