Need to replace 1 driver( lower ) for Polk RT 16 floor standing speaker...rubber is ripped on the edge. Also looking for new grills for RT16 and screw in pin ( stands ) for both
  • 4,234 Answers
Search in the area for a shop that recones speakers, you should be able to get the surround (rubber part) replaced.
Where are you located? Perhaps I can direct you to such a place.
Dan
Posted on Jul 31, 2008
Help with repairing this product, Polk suggests replacing the amp !!
To troubleshoot this you need at least an ESR meter. Capacitors can fail with no outside indication.
Jun 19, 2016 | Polk Audio DSW PRO 500 Subwoofer Speaker
Wireless bass makes popping and knocking sounds, why?
it could be the connection or your speakers could be ripped check your connection and make sure your wires are securely connected speaker is torn or ripped replace it
Mar 13, 2015 | Polk Audio Audio Players & Recorders
Polk Tweeter on RT 1000i
it sounds like its the cross over
Mar 25, 2013 | Polk Audio RT1000I Speaker
My Alesis Interactive Mobile Amp seems to have a dead battery. I was keeping an eye on the charge lights, and when it went from 3 green lights down to 1, I plugged it in to charge the battery back up. ...
change the battery, its quiet easy, but anyhow, now warrenty whatsoever!
you need:
a) one hex screwdirver size 5mm
b) 1 phillips screwdriver size 2
c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270
d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)
e) some glue
f) depending on your expertnes, 20 to 40 minutes time.
... yes thats all.
here we go
DISASSEMBLY
1. lay the unit on to back
2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)
3. remove the three edge protectors
4. unscrew the front panel (8 screws, phillips)
5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough
6. lift the grill without bending and remove it
7. unscrew the main speaker (4 screws, phillips)
8. carefully lift up the main speaker
9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew
10. unplig 2 battery leads
11. lift out te battery
ASSEMBLY
1. glue some of the foam rubber arround the new battery, take tie old battery as sample.
2. slide in the battery
3. connect the leads to the battery, the red goese to te red marked pole. Importand
4. Mount the battery holder 4 screws phillips
5. slied in the speaker, mout it wit 4 screws, phillips
6. mount the grill without bending
7. siled the frontpanel back into position and screw ist (8 screws, phillips)
8. bring the edge protectors back into position
9. Mount the edge plates (3 hex screws each)
10. put it back on the weels and load your battery. Testrun.
11. have a beer for me and enyou your music.
May 30, 2011 | Alesis TransActive Mobile PA System...
I have a blown Diaphram, and want to replace with new one. How do i gain access/open the enclosure. Its the cabinet with that hammertex material.
Almost all of these speakers now are accessed the same way... through the front.
You will USUALLY find a few small screws through the metal grille work. There MAY be some at the midway point of top to bottom as well. The grilles OFTEN "tuck" into grooves at the sides. With the screws out you usually have to pry out the grilles. Often there are rubber channels over the edges... note how they go on for reassembly. Pry out the grille at the center of the top OR use a hook with a handle to distort the grille outward so the edges come out of the grooves.
You will have some frustration getting the grille in and out... I do on mine...
Feb 13, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
Battery has died how do I replace it?
you need:
e) some glue
... yes thats all.
here we go
DISASSEMBLY
ASSEMBLY
Jan 18, 2011 | Alesis TransActive Mobile PA System...
Sound went limp i think it the crossover
Define limp. No highs or no volume?
Logically, what one thing would affect both speakers? Logically, how would a crossover failure mute anything but the tweeter?
So, what happened just BEFORE this problem appeared?
I'd look at the electronics.
Feb 25, 2010 | Polk Audio R40 Speaker
Need to find a cerwin vega 6 1//2 mid range woofer model number v-6f but i would like just the speaker only not the whole floor stand
muz782,
Replacement drivers for home speakers are only sold directly from Cerwin Vega. If you can find one online, it will not be authentic CV.
http://www.cerwinvega.com/contact_us.php
-Chris
Feb 11, 2010 | Cerwin Vega V-6F 6 1/2" 2-way...
Polk Audio Monitot 50s
Cost about $360 new. Will have to check with Polk regarding the drivers. Close call. http://www.polkaudio.com/support/dealer_sales_refunds.php
Apr 14, 2007 | Polk Audio Monitor 50 Main / Stereo...
Repairing BOSE 901 IV series speakers
The grille will come off if you try to pry it off. Then, unscrew the bad driver. Sort of new ones are sold on E-Bay for not a lot of money. Install the new driver, secure it with screws, and snap the grille back into place.
Apr 24, 2006 | Bose 901 VI Main / Stereo Speaker
42 people viewed this question
 Grubhead
Grubhead
