Question about Dishwashers
I want to plumb in a dishwasher but there is no waste pipe for the dishwasher to join on to
    Sergeant:
  • 225 Answers
If there is a kitchen sink nearby you should be able to get a plastic waste pipe adaptor from a hardware store that simply screws in below the sink plug hole and joins to the U-bend pipework. It will have a short stub pipe on it for attaching the dishwasher drain pipe.
Hope this helps. D.
Posted on Jul 31, 2008
How to connect drain pipe
There is a great video on youtube for installing a dishwasher, How To Install Dishwasher Plumbing - Replacing a Dishwasher
http://www.youtube.com/watch?v=gIr8avJFrKw
Hope this helps you.
Dec 16, 2013 | Dishwashers
Problems disconnecting the wastepipe on an AEG Dishwasher
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Oct 25, 2012 | AEG 24 in. Favorit 80800 Free-standing...
How do you plumb in a washing machine and dishwasher to the same pipes
hi just use a tee join for each set of pipes
Mar 08, 2012 | Plumbing
Does the outlet pipe have to go directly into the spigot on the kitchen sink trap? or can it go into a free standing waste pipe /
The plumbing code in your area will specify where you can or can't go with the outlet line. You wouldn't want to attach it to a line where any waste from another source would pass the dishwasher connection line, because the waste could flow back into the dishwasher. That's why you normally route it to the sink or garbage disposal (no concerns about waste from another source getting into the dishwasher line).
Mar 01, 2011 | Dishwashers
I have a brand new whirlpool DU1055XTV5 dishwasher, installed two days ago. After the cycle completes there is about 1/2" clean standing water left in the bottom. It is not just down in the well area,...
Ensure the outlet pipe is below the level of your floor and straight to a drain or plumbed into the waste pipe directly with no chance of syphoning from standing water in your drain/waste pipe.
Apr 04, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
Problems taking in water ?
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 14, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Can waste pipe be connected directly into sink waste u-bend
Yes as long as it is before the u bend (pea trap).
If you do not have the connection already there (I assume not). Go to the home improvement store and and ask the plumbing guy for the dishwasher connection. You will also need glue and primer.
Cut into your drain line and remove just enough to fit your new connection. Note that the drain slides about half and inch in at each end so leave enough to do that connection.
Clean and prime the drain lines and new fitting.
Apply glue to fitting.
Insert the new fitting.
Connect your dishwasher per instructions with your unit.
Hope this help. Please rate this solution.
Thanks
Mar 09, 2010 | Beko Dishwashers
Hi, my dishwasher type ariston LI 420 does not drain.the led 1 and 2 from left side blinking. Can you suggest me somethings. there's a file with the error led code to consult. Thanks' in advance
you might have a blockage in your filter or in the pump,first i would find out where your waste pipe goes out to if it is plumbed out through ur sink take the hose off and hold it in a bucket and turn the unit on you should hear a sucking sound and if the does now drain then have a look in the sink waste trap it is very common for the sink waste to get blocked
Oct 21, 2009 | Ariston Technologies LI640S Dishwasher
Sherwood industrial dishwasher parts I need a waste pipe
The part you need is a common part sold at most all hardware stores, lowes, home depot, or plumbing supply stores.
Mar 11, 2009 | Plumb Pak Waste & Overflow Pipe Kit, 1...
How do i change the waste pipe on a Siemens SE25235 GB dishwashe?
yes. the side panel needs removing to get access to the fill/water matrix. to do this, you need to remove 2 torx 15 sized screws underneath the white seal of the side panel. make sure you have unplugged the dishwasher and disconnected its water supply. once you have access to the water matrix, place a towel or similar absorbant material underneath where all the pipes connect to the matrix (near the back) to prevent any spillages. the waste pipe is the same colour and texture right up to the connection on the matrix and is (i believe) the furthest from the door of the dishwasher. disconnecting the hose shouldn't be too difficult.
Jan 06, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwashers Logo
163 people viewed this question
Top Dishwashers Experts
