Question about Lakewood HV 18-c Floor / Box Fan
Cleaned a fan, now it's broken!!!
I cleaned a lakewood commercial floor fan for a friend of mine and when I was done the little black box below the speed switch came apart and there are two wires running free!!. Apparently there is a cap that holds these two wires in place to make the blades run and it is missing. How do I get a replacement part??? He's very upset with me, even though he taped it and it works. I just want to replace the part.
  • catwhisperer Jul 31, 2008
    Dear dodgecharger,
    By the way, NICE CAR!! No it is not the speed switch itself. There are two other wires coming ot of the motor one orange , I think the other was red. They go to a separate little black box like a solenoid or something. One wire to one end, etc. and a cap to hold them in place!!!! Shame on me, I lost the cap!! Actually, I never saw a cap!! but apparently its missing and I want, or should I say need to replace it! (DUH). Guess he doesn't like black tape? I'll check their website, and thanks for the info. OH! You might get this twice, I'm not good with comp. either!
    Novelist:
    Champion:
  • 254 Answers
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Posted on Jul 31, 2008
  • Merwyn Bolles
    Merwyn Bolles Aug 01, 2008
    Well, maybe it is a capacitor rather than a switch box. If so, it is probably just a 2 connection device.
How can I clean a Lakewood fan, mine is so filthy and I cannot get in to clean. My husband says it does not come apart.
ok here is what I found....there should be screws on the outside rim where the two fan grates meet....then dust the innerds with a leaf blower or a rag, then use brake cleaner spray to soften the greasy dirt that formed, and again a rag to wipe away any residue....hope this works, it did for me
Oct 25, 2013 | Lakewood HV-18 Floor / Box Fan
Can I order new "feet" for Lakewood box fans
I searched for your solution. This is the closest I can find. This is customer service for Lakewood.
https://secure.jardenstore.com/ContactUs.aspx
Another solution if the above does not work. You could make a couple of feet from some wood as well.
Feb 06, 2011 | Lakewood 101 Floor / Box Fan
Motor just hums, won't turn
If you remove the cover screen and take compressed air or just a brush to clean out all dust and dirt from the motor the fan may run again
Dust is a standard contributor of these fans to quick turning
Aug 01, 2010 | Lakewood HV 18-c Floor / Box Fan
Switch broken
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Jul 10, 2010 | Lakewood 200I Floor / Box Fan
How do I clean the Lakewood tower fan
take apart the parts that come off and wipe them!
Dec 28, 2009 | Lakewood 007 Floor / Box Fan
Need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
My Lakewood box fan fell over and stopped working
As the box fan is a simple electronic, I would take the fan apart and check the solder points. If one has broken loose or is cracked, simply re-solder the point. Test it and try again. Another suggestion would be to go to your local hardware store and find some appropriate L-brackets to secure the fan to the sill while still maintaining the ability to remove it and close the window. A little human ingenuity can probably outsmart a cat. ;)
Jun 27, 2007 | Lakewood 200I Floor / Box Fan
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
May 27, 2007 | Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
528 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
