Question about Dryers
Hotpoint TDC30P runs for about 5 mins then cuts out. Have replaced thermoststs to no effect.
  • ken8 Aug 02, 2008
    Thanks, worked straight away.
  • 66 Answers
Hi its the relay behind the plastic facia normally brown with the word shrack on it with 6 wires on it this normally is the fault please leave feedback
Posted on Aug 01, 2008
Hotpoint tcl780g overheating and cutoff after 5 min.
Disconnect dryer vent and run dryer. If runs/heats normally clean out your vent.
Apr 15, 2014 | Dryers
1987 Dodge Dakota Sport 3.9L V-6 Runs beautiful for about 10 min then starts cutting out , i have to pull over but it doesnt die. When i pull over and stop the problem seems to go away, get back on th
Well the diesel effect is from the idle speed being too high or a buildup of carbon inside the engine acting as replacement spark plugs.
Can you use starting fluid to find out if the cutting out is from lack of fuel ?
Jan 21, 2014 | Dodge Dakota Cars & Trucks
My hotpoint TDC30 dryer is cutting out after 3 mins ,the drum is warm inside and wont restart till its cold inside the drum
Hi joanne balla...
Sounds like the cyclic thermostat, thermostat, fuse (differnet names for the same part)..is faulty...replace it.
You will have to remove the back from the machine, look for the air tube going to the vent of your dryer and located on it will be the thermostat/s.
To test it, remove the wires fromthe two terminals and tape them together, then try running your dryer again and if it runs and heats ok then replace the cyclic thermostat/fuse.
Go to the following webpage to see the thermostat
Please take time to rate me
http://www.espares.co.uk/parts/tumble-dryers/thermostats/hotpoint/p/1587/808
Sep 13, 2011 | Hotpoint Dryers
I have aquarius ,, lights keep flashing prior to
had a similar problem...sounds daft but have you unplugged it left it alone for 5 mins then tryed again? worked for mine.
Mar 02, 2010 | Hotpoint Washing Machines
Need to find the front thermastate on my hotpoint tdc30p tumble dryer
i think you need to take the front panel of for this one here is a video on the back ones. We have a full video library on appliance repair video’s
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Jan 02, 2010 | Hotpoint Dryers
Have a hotpoint tdc30p dryer that will not heat
Check to see if the new parts fitted are o/k,
If they are, then your problem is probably a faulty control unit or possibly bad connection in the wiring.
If the new parts are faulty, then something else is causing them to fail.
Make sure all filters are clean and that all air vents are clear
Dec 12, 2008 | Hotpoint TDC32 Electric Dryer
Start button needs to be held in to work on TDC30p
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
CALL BACK YOUR SERVICE GUYS AND TELL THEM IT DID NOT WORK. THEY SHOULD NOT RECHARGE YOU FOR LABOR BUT CREDIT THE LABOR TO THE NEXT CALL SINCE THEY DID NOT FIX IT!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 20, 2008 | Hotpoint TDC32 Electric Dryer
No heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
Dec 23, 2007 | Hotpoint TDC32 Electric Dryer
Aquarious condenser dryer
hi there the problem you have there is a faulty start relay located behind the control panel accesed by removing lid.
part no for relay is C00095530
Dec 08, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
182 people viewed this question
Top Dryers Experts
