I have a Ferguson radiogramme c. 1950. It is in need of repair and I would appreciate name of possible helper.
  • 10,594 Answers
Well, you can find a repairman near you at fixya.com main page. there is a search box named ("Repair Service" Find a Repairman Near You) Hope it might help you. Have nice day!
Posted on Jul 31, 2008
  • Shahid Electronics
    Shahid Electronics Aug 03, 2008
    • did you find any repairman?
  • 13,433 Answers
It debends on where you are located, here is one
http://www.vintageampdoctor.co.uk/
thats outside of usa
How would i go about finding parts to a Harry Ferguson 1939 ttractor. I need head bolts. 7/16 x 20mm. Supposted to be compatible with Henry Fords 9N.i dont know how to search for this.
First there isn't any metrics to a 1939 ford. 7/16ths X 14, X 20, X 28. are the thread sizes. The last number is threads per inch. You need to measure the length of the bolt. Grade 8 is usually the hardest.
Oct 22, 2016 | Cars & Trucks
How can I get a copy of a wiring diagram 1950 ferguson tractor 10-35,with 12 volt gen.
perhaps a FORD tractor dealer could find one for you
Mar 03, 2016 | Toys
We need a Repair manual
Hi Susan:
Here's a link that will give you a huge number of contacts where you should be able to find the info that you need.
https://www.google.ca/#q=massey+ferguson+231S+tractor
Cheers and Happy New Year.
Jan 01, 2016 | Toys
Who has manuals for the Massey Ferguson 230?
contact the manufacturer on line for any available pdf downloads.
try e-bay for manuals.
May 04, 2015 | RTO Massey-Ferguson Tractor TE20, TO20,...
How do I fix a clutch on Massey Ferguson 165 1979 tractor. I need a manual to do repair on farm
This is easy. If you live on a farm i assume you have some mechanic abilities. the tractor needs to be split in half. I have done these tractors in as little as 4 hrs. The easy way to seperate the tractor is to sleightly jack up the middle of the tractor,put a jack stand under the front of the transmision. Now move the floor jack forward to the rear of the engine. take roughly half of the weight off of the jack stand. this will allow you to roll the front half of the tractor away from the rear once you remove the trans.bolts,hydro.lines and brake rods.
Sep 15, 2014 | A&I Products A-509057M91,Massey...
Ignition switch diagram
IF you have a locksmith take it out it is possible that he may be able to repair the pins in the tumbler but I think the cost would be more than getting a new tumbler. If you use a locksmith then he can set the new tumbler pins so that you can use the old key and that will save you carrying extra keys unnecessarily.
Dec 30, 2013 | Dodge Cars & Trucks
Need a service manual Massey-Ferguson 135
This store seems to have tons of Massey manuals and some for the 135 tractor: Massey Ferguson Manuals
Jul 02, 2013 | A&I Products A-509057M91,Massey...
1950 massey ferguson timing gear alignment
what are the timing marks for a massey ferguson tef 20 1955 to put the timing back on
Apr 16, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
1960 massey ferguson hydraulic filter location
Hello, I would say just go to a NAPA parts store and ask for a filter. If they have one they would show a part number for it. Usually the older tractors for Ford and Ferguson did not use filters or at best had metal filters that you cleaned in solvent and reused. There are Repair Manuals in soft-cover which are available at places like Tractor Supply or online.
The old tractor makers considered the transmission and differential sealed systems. This means like your new car today does not have a filter in the differential. The old tractors had manual transmissions and the filters are common in automatics.
Be careful not to overfill the trans because on old tractors the gear lube will go out the axle tubes and into the brakes. If operated on a slope, it is possible to tilt the axle tube and have the excess lube flow into the low side axle tube, ruining the brakes.
Some of the parts for the Ferguson will interchange with the N Series Ford. Ferguson had some Industry innovations that later were stolen by other makers.
Oct 03, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
I have a 1950 ferguson to20 lift arm will not lift any weight ? this problem just happened is this a simple fix? like o-rings, check balls??? Thanks
maybe, If the hydro fluid level is up then you most likely need to change or clean the hydro filter. when they stop up they will cause it to cavitate. cavitation will add air bubbles to the fluid and make it look a little milky. It would be best if you can drain it and add new. please let us know if this helps. note that they will usually be jerky on lifting just befor no lift.
Aug 31, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
 Grubhead
Grubhead
