Question about Vacuums
Hi i have a dyson DC 05 (yellow) vacuum which is playing up. it refuses to come on, but sometimes when you waggle the flex a bit it works after a while. Any ideas how I can get into the flex housing?
  • 3 Answers
Thats your trouble You have a Dyson
Posted on Aug 13, 2008
  • jnayback Aug 13, 2008
    It was my understanding the dyson had a lifetime warrenty?
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
My dc-15 bush bar will not work
Head motor blown, will have to take it to your nearest good hoover repair centre should cost around 49 dyson will charge 73
Jan 14, 2013 | Dyson 909592-05 DC-15 Roller Brush Beater...
Dyson dc 05
I'm sorry to hear you've had difficulties with your DC05. If the machine won't run at all, I'd encourage you to get in touch with us directly so we can help. You can reach us on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 25, 2012 | Dyson DC05 Bagless Canister Cyclonic...
My dc 18 has stopped working properly....there seems to be extra air going into it from the black rubber circle at the top and its refusing to pick up......nothing is blocked and brushes working just fine
I'm sorry to hear you're having difficulties with your DC18. We'd appreciate the opportunity to run through some troubleshooting over the phone with you to determine the cause of the issue. We may be able to fix the machine right over the phone.
Please give us a call free on 0800 298 0298 (UK), or 1866MYDYSON (US) so we can help. We'll look forward to hearing from you.
Kind regards,
Jack
Nov 28, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson Slim DC 18 all floors has no suction from the beater bar, but works great from the hose.
Hi its Darran at Dyson.
Its possible that the brush bar is not turning when you release the head into the vacuuming position. Please ensure you complete a full blockage procedure as per your user guide to see if this resolves the problem. If you do not have a copy of the user guide to hand, please visit the Support section on our website at www.dyson.com.
Alternatively, if you still need some help or advice with your Dyson, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 23, 2010 | Dyson Slim DC18 All Floors HEPA Bagless...
My dc 05 isnt working and i cant understand why , i have cleaned all filters etc and i also changed the fuse on the plug , which after i didi that it attempted to start but then jus cut out again so i...
Most common cause of this problem is a wire broken inside the flex, usually either just where it leaves the plug (easy to fix) or at the other end (more of a problem). In either case, this is no reason to dump the machine - it can be fixed at a fraction of the cost of a new one.
If you need guidance on what to actually do about this, post a reply here, saying what country you are in please.
Feb 17, 2010 | Dyson DC05 Cylinder Bagless Canister...
The brush bar wont spin on my dyson dc 25... i
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
We have a dyson dc 07 animal the machine was working fine then switched off after returning to the machine minutes later it wouldnt switch on, i removed on off switch cover and used a short piece of wire...
It could be the motor. I'm having to replace the brushes on my DC 05. It appears that you can only get brushes for the YDK motors in the DYSON, not the Panasonic motor. Which might be saying something about the YDK motors. What happens is that the carbon brushes wear down which is normal. However, the contact wire from the brush to its connector is set so that when the brush wears down, the wire is short enough to stop the spring etc from damaging the commutator. The end result is that you get an intermittent operation of the motor before it finally dies.
I believe all the DYSONs come with the option of both motors and you cannot really tell which motor you have until you take the thing to bits. You also cannot change motors without changing various other parts on the hoover. On my DC 05 the writing on the YDK motor tells you which one it is.
This website www. tasweb.org ,select the DC 05 option and scroll down tells you how to take the thing to bits. A search on google etc for your DC 07 may give similar results. Best of luck!
Jun 20, 2009 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC 14 animal bagless--unable to use wand
Hi.
Try these tests & tell me the results.
Remove the hose & wand completely from the machine it unclips at the bottom of the back.
Leave handle in full upright position & switch on do you still get the sound of something blocked ?
If yes remove the (U) shaped inspection port again at bottom back of machine now repeat last test what happens ?
Please reply with your answers.
http://dysonmanuals.llc.nu/index.htm
Chris.
May 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson
Hi.
Check mains lead where it enters machine very common for internal fracture.
To prove this try waggling lead with machine switched on if it starts & stops this is the fault.
http://dc07.atspace.com/
Chris..
Dec 23, 2007 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
