Question about Fisher Paykel EcoSmart GWL15
My FisherPaykel ecosmart washer will not spin out and drain. What can I do?
My washer will run through it's cycle but stops at the final spin and won't go any further. It just sits and beeps at me. I have tried removing all the
water and unplugging the unit and trying again...but the same thing continues to happen. Please Help!
  • jjbolden61 Jul 31, 2008
    My FisherPaykel ecosmart is not going through the final spin and will not drain.
    Genius:
  • 1,011 Answers
Have u checked by changing the time period. if it happens same as by selecting different time then try it for different speed by selecting the speed options.
i think there is something wrong in washing steps that are being adapted by u. so plz take a look in instruction manual .
here it is:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=5280076ca6e228ec12ed05bd1e510181&q=Fisher+%26+Paykel+GWL15
regard,
dont forget to rate it plz
Posted on Jul 31, 2008
  • 2,071 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE?
My FisherPaykel ecosmart washer will not spin out  - small_11_21.jpg For a detailed Washing Machine illustration, click below.
Top Load Whirlpool Style
Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
  • 13,433 Answers
See if this page is helpful to you
http://www.repairclinic.com/0088_11_1.asp
If not- then click on repost problem(or request more advice I dont remember what it says) to get more advice from other experts.
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
I have lost my instruction manual. It is Fisher & Paykel model GW611 I want to know how to turn off favorites and reprogram it in again
From what I can tell, GW611 is an Ecosmart:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/420653_US_Ecosmart_UC.pdf
There are a few different Ecosmart manuals on the Fisher & Paykel website, so you might be able to find one that matches the button shapes you have. They all seem to have the same Favorite instructions:
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Jul 16, 2011 | Fisher and Paykel Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
My f&p is not draining or spinning
You have a broken lid switch that needs to be replaced. The washer thinks the lid is open. A model # would be helpful. thanks dave www.washermd.com
Dec 16, 2008 | Fisher Paykel EcoSmart GWL15
Fisherpaykel gwl15 washer will not pump down
remove as much water as possible lean washer back against wall ..pump twist locks into bottom of tub remove clamps with fingers pump will twist out no tools needed!!!! clean pump and retry
Sep 09, 2008 | Fisher Paykel EcoSmart GWL15
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
177 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
levittg
Level 1 Expert
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
