Question about Tomtom GPS
After inserting a 1 gig sd card and copying the relevant software across using tomtom home, the unit switches on then goes to a screen that says please wait in about 5 different languages and an egg timer, then does nothing the only way to get out of this screen is to reset the unit. The old 256mg card with the same software on it works just fine when reinserted. Does the TomTom unit not like 1 gig cards
Delete everything on the card with windows i.e. double click on my computer select whatever drive letter it has asigned to the memory card in your TomTom unit, then select all and delete. Then restart TomTom home copy relevant software across or use the backup facility and everything worked just fine.
Posted on Aug 02, 2008
Tomtom one (4N00.012) will not load up.
Your particular unit runs it's software from SD-Card. you need to check if the card is not damaged: while unpowered push the SD card to come out insert it in a card reader on your computer and see if it reads it ok, if it ask's you to format it it means it's damaged and should be replaced ( the sd card of your tomtom should be replaced with another SD card which you should buy from tomtom for your particular device not a generic one). if it reads just fine reinsert it and start the device again..And about the reset the correct procedure is: Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.904537f.gif
You should also install Tomtom Home on your computer, connect the device and update it if al the above failed (with a verified and working SD card inserted) - link for Tomtom Home: Windows, Mac
May 30, 2010 | Tomtom ONE 125 GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
When turning on the no maps appears on screen
If you have an SD card installed then
Remove the SD card from the tomtom
The card may need to be formatted properly first or re-formatted.
Formatting is better done in a card reader.
There are differing views but this method has always worked for me.
Insert the card in the reader,. Using my computer or windows explorer right click on it and select format
Now connect the tomtom to the pc but don't let tomtom home run.
Exit TomTom Home if need be.
You now need to select your tom tom which will also show as a drive and may even show its own special icon.
then just copy ALL the files from the tom tom to your sd card.
Once all the files are on your new card switch off the tom tom and insert the sd card and re-boot the TomTom
It should now work.
If not try the hard re-set in which you would use a paperclip to reset the tomtom. there should be a tiny hole on the underside of the unti.
push the paperclip in there (not too hard) while the unit is switched on
This would cause a reset to factory defaults (you may have to set home location etc)
You may also have to switch off and re-boot again for it to take effect.
Aug 28, 2009 | Tomtom One XL GPS Receiver
I have a tomtom xl and when i turn it on the unit rejects the sim card and as a on screen symbul of a man with is hand out with a red x through it .
Then just copy ALL the files from the tom tom to your sd card.
It should now work.
Formatting a tomtom go 710
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Nov 15, 2008 | Tomtom GO 700 GPS Receiver
SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
Jan 09, 2008 | Tomtom ONE GPS Receiver
Tomtom one
Hi Steve de may.
Try removing your SD card and inserting again. If the problem persists then I recommend you use your backed up copy to restore the SD card. You did make a back up on your PC, right?
The other possibility is that in the preferences section of you tom tom the wrong map has been selected or a map that it cannot read has been loaded. Remember newly purchased maps must be activated first before use.
I made a copy of may original SD card and use that in my tomtom. If anything goes wrong, I can always restore it from the original. I also made a copy on my PC using the Tomtom "Home" application.
Hope this helps.
Regards,
Spare head 2.
Jan 03, 2008 | Tomtom ONE GPS Receiver
Tomtom 1
You cannot use a sd card from another tomtom. The sd card is coded for each individual device. About the only thing you can do is to purchase a 1 gb card (no larger because it won't be supported). Insert the blank card into your unit and connect it to your pc. Go to my computer and see which drive the tt is. format the card and then open tomtom home. This will load your operating system back onto your card. I don't know if you can download a free map or not. Check the tomtom forums for more information concerning maps.
Hope this helps
Oct 13, 2007 | Tomtom ONE GPS Receiver
GPS Logo
56 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
