Question about Veo Stingray
Video time limitation
As I was recording a video, it stopped recording after a short time about 10-20 seconds. How do I increase the memory for recording so I can make a longer video?
  • Anonymous Jan 17, 2009
    free man needs a web cam pls
Saftwar
Posted on Jul 31, 2008
How do I increase the recording time on a Nikon Coolpixl830?
I do not own this camera. I will use common sense. Taking moves need lots of memory and lots of power. If you have a nearly full memory card or a weak battery your recording time will be limited. Taking movies in any camera runs the DSP (inside the camera) hard and fast. This causes excess heat. If the camera gets too hot it will stop taking movies. It is memory, power and temperature.
Mar 09, 2015 | Nikon Coolpix L830 16.0 Megapixel Black...
Hi, I own a Nokia 5230. Before, I was able to record video smoothly and clearly without any kind of problem. Now, 90% of the time when I video, the video keeps going when recording, but the timer...
check if the phone memory is still at large and so on the memory card to,might so many files from your phone or card that's why the operation took some errors or buffer...
otherwise if this problem took on and so on,better reset your phone or restore it to it's factory default to refresh the memory of the phone and can do the operation smoothly...
if this solution helps....please rate me...thanks
Jun 03, 2011 | Cell Phones
Why does the canon 550d stop video recording automatically when there is enough battery and memory
There are two possible reasons. The first one is a file size limitation. The size of a file is stored as a 32-bit number, so when you get to 4Gb, the file size is 'full' and can't be a bigger number; thus, if you're recording in HD you might get to this 4Gb 'brick wall' first. I think it comes at about 12 minutes.
The second is an artificial limitation made for tax purposes. Even if you choose a lower resolution, your recording will stop at 29:59, or one second short of 30 minutes. This is because the EU imposes a hefty tax on any device they call a 'camcorder'. They define camcorder as something that can record for 30 minutes or more. Therefore they stop the recording at 29:59 to avoid being defined as a camcorder, and hence avoiding the tax.
Feb 17, 2011 | Canon Cameras
Samsung VP D31 stopped recording video - just black screen
my samsung vpd230 has stoped recording, just a black screen,
would you also explain what a ccp is,also the words memory stick keeps keeps appearing.thankyou
Apr 06, 2010 | Samsung VP-D31 Mini DV Digital Camcorder
How do i get video to workon my vivitar vivicam x327
Video Mode
Press the MODE button to select the Video mode.
Note: The camera has limited internal memory allowing you to record up to 20 seconds in QVGA. An SD
card (up to 8GB) needs to be inserted in order to use the video mode normally.
When the icon appears on the top left corner of the LCD screen this indicates that you are in Video
mode.
1. Prepare the object or subject you wish to record.
2. Press the Shutter button to begin shooting the video.
3. The elapse time will appear on the top right of the LCD screen and the icon will flash on the
LCD screen.
4. Press the Shutter button again to stop the recording and save this file in AVI format.
Note:
1. You can preview the AVI files in Playback mode or once downloaded to your computer by using
Quick Time and Windows Media Player.
2. When the camera's memory is full, the “Memory Full Insert a SD Memory Card to Transfer and
Shoot More video!” message will appear on the LCD screen when you attempt shoot more videos.
Download the test file from the internal memory to the PC or delete them to shoot more videos.
27
Alternatively, you can insert a SD memory card to expand the memory to record longer videos.
3. The LED will light up when the light condition is not good.
Feb 22, 2010 | Vivitar ViviCam X327 Digital Camera
How to set the recording length maximum in n72
While on video mode press options and select settings. Scroll down to Video quality and change to High or Normal. On Memory in use, select memory card. The length of video recording is restricted by the available space on your memory card and up to one hour per clip.
Aug 31, 2009 | Nokia N72 Cellular Phone
Video shoot problem
Download P2k advance editor from www.modmymoto.com. Extract it on your Computer. Then connect your phone via usb. run the P2kAE and select connect then go to services or something but its on the second. then go to video camera and select read from phone then increase the recording memory from 50Kb to 50Mb or higher if required you can also save videos in mp4 format. Note: don't go beyond the size of the memory card.
Dec 03, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Installing a video recording software with more recording time
try the application camcorder pro....unlimited video recording depending on the free memory of your memory card
Feb 16, 2008 | Nokia 3650
Aiptek IS DV2
Seems like its time to flush the contents of the memory card of camcorder to a computer.
There's a limited amount of memory in every memory card. After constant recording, the memory  gets full and the recorded stuff needs to be either deleted or flushed (uploaded to a computer) to make room for newly recorded stuff.
Unless you have a blank memory card, your problem should be solved by the above mentioned idea.
Oct 20, 2007 | Aiptek IS-DV2 Camcorder
Veo Stingray Logo
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
