Question about Belkin (F5D5231-4) Router
Ibought new Belkin router it totally not working I try to thorugh cable even
    Novelist:
  • 144 Answers
Hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Posted on Aug 01, 2008
I can't get my Belkin G Wireless router to work with my Clear WiMax modem even after keying in the security key..is this router compatible with this modem?
Any router should work with any modem. Make sure you are running an ethernet cable from the WAN/Uplink port of the router to the modem, or in some cases it will be a USB cable. Also you can test your internet connection by plugging a computer directly into the modem.
Apr 04, 2012 | Belkin Computers & Internet
My belkin basic router is not working
well you can fix such kind of problems via contacting to belkin tech support. for more help you may visit: Belkin Tech Support Helpline
Sep 10, 2010 | Belkin (F5D5231-4) Router
I have a Belkin N+ router and I am trying to use the USB storage sharing feature. I have a WD HDD mounted in an Ultra external enclosure. When I plug the HDD into the router, the storage LED on the router...
it says the HDD is not compatible with the router.... it might be due to the file system in HDD....
At this moment, the Belkin N+ Router and Modem-Router, F5D8235 and F5D8635 work with the FAT, FAT32, and NTFS file systems only.
Versions of the F5D8235 firmware earlier than 1.01.24 may fail to detect a drive that contains a mix of supported and unsupported file systems. This was fixed in firmware 1.01.24, available from the Belkin UK Support Site
We have seen a few compatibility problems with drives not being recognised and we are investigating these to get them fixed.
We have also seen occasions where a drive was not detected by the router or modem-router due to a poor quality USB cable. If a bus-powered drive does not spin up, the first thing to do is to make sure that a good quality cable is used. Even self-powered drives may fail to be recognised when using poor quality cables. Even though the cable may work when the drive is connected direct to a PC, always try a different (good quality) cable as part of troubleshooting drive detection problems.
Tech Support: If you come across a drive that is not being recognised by the Router or Modem-Router, please check on the hidden page http://192.168.2.1/storage_disk.html if the router has detected anything at all. Make sure that the drive works when connected directly to a Windows computer and try a good quality USB cable as mentioned above.
Apr 24, 2010 | Belkin F5D8236-4 Router
My belkin 54g wifi router is making a new DHCP request to my isp every 4 minute or so - the lease time is set to "1200"
the lease time should be forever..... even after changing the lease time if you have the same issue, try updating the firmware of your router.... you can download the latest firmware for your router from the link below....
www.belkin.com/support
Apr 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect to the internet
You cannot connect a router to a router. You would have to configure the belkin as an access point and I don't believe those routers can work that way.
Basically you cannot have a router "routing IPs" when another router is already doing that work. There will be a conflict and the second router will always fail.
Feb 15, 2010 | Belkin (F5D7230-4) Router (587009)
I HAVE BELKIN I TRYING TO CONECT SECOND DESK TOP TO IT ,ICAN IT TO WORK
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Click Here for more info
Dec 14, 2009 | Belkin F5D8236-4 Router
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Belkin (F5D5231-4) Router Logo
47 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
