Question about Nikon Speedlight SB-800 TTL Flash
The flash shooting distance range does not appear at horizontal position.
My Speedlight SB-800 has been hard pressed due to a mistake. :-(
It had a crack in the front glass and minor damage at the Flash head tilting/rotating lock release button.
I have fixed both problems and the flash seems to function normaly, exept for one thing. The flash shooting distance range does not appear at horizontal position, but only at 60, 75 and 90 degrease, whitch is totaly wrong.
Because of the repair, I opened the flashhead, but could not find anything that could give that wrong position-signal.
Did anyone know, what could be wrong?
Jens Roelle
  • 2jr8 Aug 03, 2008
    Thank you Junoon007, but I have tried that.
    I also have tried to do what the expert Aviorix (I think) suggest me to do, to go deeper.
    It's very difficult to get the plasticshells of, even when all screws are removed, but I forced it to open enough to remove the plasticdisc, who told the position of the head.
    It has two very small metal pickups underneath, moving on a printboard. They were bend backward and when I bend them back to normal again, they broke.
    I don't knew, if I can get this disc as a sparepart, but now I will assemble the parts and see that happens, when there is no pickups. If it shows the shootingdistance in all angels, I can live with that.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Doing the resetting the settings it will be fixed. Press a and b approximately 2 seconds reset all setting, including the custom settings.
Control panel quick reference
Procedures for custom settings, recalling the underexposure value in the TTL auto flash mode, resetting all settings to their default value
Posted on Aug 01, 2008
  • 10,594 Answers
Please open flash cabinet again and check any Jack/ connector can be lose. Becareful while open tha flash because it has high voltage inside.
  • Shahid Electronics
    Shahid Electronics Aug 03, 2008
    • Do you read my suggestion?
How I can reset factory set from Nikon Speedlight SB-600?
To reset your Nikon Speedlight SB-600 you need to press Mode + ON/OFF, both buttons simultaneously for approximately 2 seconds to reset all settings, including the custom settings (except the distance unit selected in m/ft) to their default values.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Oct 01, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a Nikon D40x with a Nikon Speedlight SB-800. The speedlight is not working. I have the camera on, new batteries in the speedlight and speedlight on. Not powering up. Is there some secret battery...
With new batteries in the flash, and it being off camera what happens when you press the test button. If still it does not flash call Nikon 1-800-645-6689
Aug 14, 2010 | Nikon Speedlight SB-800 TTL Flash
Will give correct expoures in ttl
Hard to tell what might be going on without knowing what camera you are using or what shooting mode the camera is in.
What I do is set my camera to Manual. Then set the shutter speed for 1/60th a second. Try a shot with the SB-800 attached - firing directly at a subject that is about 6 feet away and check your image.
To expand the range of the flash, you can change the ISO setting. Adjusting from ISO 200 to 800 will allow you to expose more background. Depending on the camera you are using, this may also introduce more noise in the image.
Mar 22, 2010 | Nikon Speedlight SB-800 TTL Flash
Sync Nikon SB-800 speedlight with studio lights
keep the Sb 800on the camera hot shoe and elichrome will trigger automati or use a slave unit
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikon D70s will not shoot
Make sure the hotshoe is clean, this will give the hotshoe a better connection. Make sure you lock the speedlight into place.
Oct 08, 2008 | Nikon Speedlight SB-800 TTL Flash
TTL Multi-Flash Sync Cord SC-27
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Settings for sb-800 to control external sb-600
set the SB-800 as the commander and SB-600 as the slave. Press and hold the mode button to open up the menu and select the options.
Mar 25, 2008 | Nikon Speedlight SB-800 TTL Flash
New SB-800 died
CHECK THE BATTERY CONTACTS AND MAKE SURE THEY ARE TOUCHING. iF THIS IS NOT THE PROBLEM THEN
YOU HAVE TO SNED IT BACK TO THE FACTORY WITH RECIEPT FOR WARRANTY REPAIR .
'THE MAIN BOARD IS DEFECTIVE
Mar 29, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
105 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
