Question about Panasonic PV-GS300 Mini DV Digital Camcorder
Sd card error
I have formatted my sd card with win xp-sp-2 and my camcoder nv gs300 can not read the sd card. it is showing card error. what should i do. though the card is working fine with other devices.
5 Suggested Answers
cropp
  • 377 Answers
SOURCE: Re: WMM doesn't detect my panasonic nv-gs27
hi dear
just using card fire wire
and transfer it with software like: , pinacle, Ulead Video Editor, adobe premiere ...sony vegas ...cyberlink power director.and many moore
oke
cropp
Posted on Mar 21, 2008
micromaster
  • 3614 Answers
SOURCE: HDC - SD5 Software Won't Install On Win XP SP 3
I will try to look for the software for that..
micro
Posted on Jun 07, 2008
SOURCE: Driver for my JVC camcoder model GR-D73AS to work with Win XP
Maybe it works
http://www.mediafire.com/?g4mo4ndhti1
Posted on Feb 15, 2009
muntejaya
  • 10421 Answers
SOURCE: i m using win 7
Please get it downloaded her : www.nodevice.com/driver/.../Panasonic/Camcorder.html
Posted on Feb 15, 2011
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
Dec 21, 2013 | Electronics - Others
Can I use a 8gig SDHC card in my panasonic nv-ds65 ?
The NV-DS65 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in this camcorder. You need to use SD cards 2GB and smaller.
May 04, 2012 | Panasonic Cameras
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
1.cassette can't playback 2.SD card can't read
please take the camcoder to a tech or return to manufacturer if it still has warranty cos its not likely a problem you can fix yourself...
it may require simple things like cleaning tape head a re-inserting memory card or changing it
or require more technical details....
Feb 13, 2011 | Sharp VLZ7U Camcorder
I want to install xp sp-2 32 bit on my lenovo g560 already having win7 32 bit can i install win xp ???? i want to format my only c drive and i want to keep both o.s. on my system. please help me.
you will not be able to do that because if you format c: drive you will loose Win 7, you can though, partition the c: drive and then add winxp to the new drive which should be d: drive now by booting from xp disk and choosing to install on d: drive only
Dec 14, 2010 | Lenovo G560 06793JU Notebook
No sound card installed Xp automatically
you need to find what kind of soundcard you have and download then install the drivers for that sound card, open up the case if you have to and try to read what brand the card is and what model it is, then go online and get the drivers, that should fix your problem
Jun 15, 2009 | AudioBahn ALD28X 2-Channel High...
Sd elite pro 2gb
What is the error message you are getting?
Have you formatted the memory card?
Jun 09, 2008 | Canon MV730i Mini DV Digital Camcorder
Card Protected
take the card out it will have a switch on the side of it that locks and unlocks
Feb 08, 2008 | Polaroid CAA-03040S Camcorder
Plug in to the computer...
It sounds like you're plugging the camcorder in  via USB. Your PC is looking for a flash memory card (SD card on the GS300), which is used on that camcoder for still photos only.
If you want to transfer video from the camcorder, you need to use the Firewire port. DV camcorders do not transferr video via USB (some of the "computer" style camcorders, including most flash, DVD and HDD camcorders, can use USB for file transfers).
Jan 21, 2008 | Panasonic PV-GS300 Mini DV Digital...
Open Questions:
Panasonic PV-GS300 Mini DV Digital Camcorder Logo
100 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
