Question about Sharp LC32SB28UT 32 in. HDTV LCD
Does Sharp LC-42SB48UT TV support PAL ? if anyone has this TV you can search under the Option Menu to "Select the video signal system compatible with your equipment from the list below:" Auto/NTSC/PAL-M/PAL-N ? Could you please tell me if there are PAL-M and PAL-N ?
    Genius:
  • 1,036 Answers
PAL-M is 525 line 29.97 frames per sec, PAL-N is 625 line 50 frames per sec. Most countries (e.g. UK) use PAL B/G/D/K/I which is 625 line 25 frames per sec. PAl-M is used in Brazil, PAL-N is used in Uraguay and Paraguay. Most modern TVs will handle both PAL and NTSC as long as the RGB input is used (via scart or HDMI).
Posted on Mar 08, 2011
SOURCE:
I bought a Sharp Aquos LC 32LLE260M TV from Malaysia and I couldn't program it to Australia channels.
you have to go to onscreen menu
find the section where is has a list of systems and click on the PAL system as that is used in Australia
Malaya and Asian countries use different systems
after that go to auto tune and all the channels and radios should come in
Oct 30, 2016 | Sharp Televison & Video
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Got no picture but i have sound on my sharp lc-42sb48ut how do i test the t-con board backlight inverter and power supply board?
Normally u have this problem for a while before they just stop showing picture period U can only try unplugging it and try to restart it unfortuneatly this is the problems with LCD TV,s when they play out I know i had one go this way after only 3 years old and cheaper to replace then to try to fix.....#Laborcosts
Nov 03, 2014 | Sharp LC-42SB48UT 42" LCD TV 1920x1080,...
Manual for shap 42 lc-42sb48ut
http://www.google.com.ph/url?sa=t&rct=j&q=shap%2042%20lc-42sb48ut%20manual&source=web&cd=2&ved=0CCsQFjAB&url=http%3A%2F%2Ffiles.sharpusa.com%2FDownloads%2FForHome%2FHomeEntertainment%2FLCDTVs%2FManuals%2Ftel_man_LC32SB28UT_42SB48UT.pdf&ei=gnPJToP8EcmgmQX-xbwP&usg=AFQjCNFcndpoltc3KU8SuBqgyCUaLzh0dw&cad=rja
Nov 10, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
No sound from TV - Sharp TV LC-32GPIU
Check to make sure you have the speakers tuned on in the setup menu, and you are not in sap.
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Default input when turning on the TV
From the menu select Option, then select Input Select, then select the signal type you want to use on startup, set to Auto, then press menu to exit. let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 12, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Help
Go to menu and sub menu video .Under video option you will see video formatt,e.g Pal,NTSC.You confrim your tv standered if its pal or NTSC (this you can check at back of your tv set ,not always mention but most of them are printed)On your dvd player
you have to select same formatt as your tv .If not sure of you tv system try auto system on you player.
NB dont select progressive scan by mistake otherwise you will not see any picture on your tv if its not progressive scan tv.
If you could mention tv and dvd model and brand will be able to advise you exactly.
Dec 13, 2007 | Televison & Video
Sharp LC32SB28UT 32 in. HDTV LCD Logo
234 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
