Question about Tally Office Equipment & Supplies
How to print a configuration page from a Tally T6215 printer
Posted on Dec 19, 2008
    Problem Solver:
  • 26 Answers
Go to printers in the control panel of ur computer. Click properties and then click on the print configuration or printer test page.
Posted on Jul 31, 2008
2 Suggested Answers
  • 169 Answers
SOURCE: Tally t6215 is printing continuously,
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Posted on Dec 12, 2011
Tally t6215 page break
It is probably not the printer problem . First confirm it by taking 2-3 windows test pages . If it is coming properly than your problem is surely form the package you are using. Ask the system administrator to rectify the problem from the software . page length and printer emulation must be added in the software.
Jan 10, 2013 | Tally T6215 Matrix Printer
LCD PANEL SHOWS ONLINE CONFIG1+ SHOULD THAT BE THERE? I CAN'T GET IT TO PRINT
The Online Config 1+ message is telling you the printer is Online ready to receive data and Configuration set 1 is loaded.
The + is indicated as the platten gap is set for thicker paper.
If the printer is not printing I would suspect a system or communication problem.
If the printer makes a noise like it is printing perhaps try closing the print head gap.
Sep 07, 2011 | Tally T6215 Matrix Printer
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
Dec 22, 2010 | Tally T6215 Matrix Printer
How do you set the printer to print continously without loosing settings on the next page?
You need to save the settings via the operator panel.
Goto CONFIG Menu -> CONFIGURATIONS -> SAVE -> and save the current configurtion to a template, e.g. CONFIG 1.
Mar 29, 2010 | Tally T6215 Matrix Printer
Tally6215 "Config 1" Error
The 'Config 1" message on the T6215 is not indicating an error message, this message is simply indicating that Config 1 of the 10 configurations that you can set on the T6125 is loaded.
With the Config 1 message loaded you should still be able to print so long as the printer is ONLINE and does not have any other error lights on.
If the printer is not printing I would recommend printing a configuration page to check the printer is working OK.
To print a configuration page follow these steps;
Put the printer OFFLINE
Press the MENU BUTTON
Press the DOWN ARROW to HELP
Press ENTER
The printer should print a configuration page, if this prints correctly I would recommend checking the settings in particular the Interface and Emulation settings.
I would also recommend checking connectivity between the system and the printer to check the print jobs can get to the printer.
Also check the system to ensure the correct printer driver and printer setup is being chosen.
Mar 26, 2009 | Tally T6215 Matrix Printer
Tally T6215 does not power up
There is two reason behind the problem (1)Power Supply . (2) logic Board. At first check the power supply if the power supply is ok then change the logic board.
Jun 12, 2008 | Tally Line Matrix T6215 Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
1,126 people viewed this question
Top Tally Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
