Question about Zanussi Dishwashers
Zanussi aquaius DE 6855, starts off ok ,rinses ,but then stops and wont pump the water out and the lights start to flash on and off. Any ideas
Either the exit hose does not reach a high enough point or the waste-pipe is blocked. I had this problem in both situations.
Posted on Sep 10, 2008
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
I have a zanussi izzi and it works ok for about a minute and then it stops working and the programme light starts flashing continuosly?? any ideas?? water comes in fine and wash pump works for about a...
Hi
The issue can either be with the unit not draining properly or the timer/electronic board itself has gone bad & should be replaced. First clean the drain hose and the drain pump for any clogs, you can do this by taking off the bottom access panel. After cleaning if still the issue is not resolved then the timer/control board has gone bad and needs to be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 12, 2011 | Zanussi 24 in. IZZI ALU Built-In...
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Dishwasher not getting hot or drying
Same Problem Here - I Noticed your Post is quite old - Please did you solve the problem my friend..........???
Dexpex@hotmail.com
Apr 29, 2009 | Zanussi 24 in. DE6844ALU Free-standing...
Zanussi FS 1355 w Drum not turning
DEFF BRUSHES.JUST HAVE SAME PROBLEM MYSELF NOW AND TOUCHED BRUSH HOLDER SLIGHTLY AND RESTARTED..
Jan 01, 2009 | Zanussi FS1455W Front Load Washer
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Dec 01, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Dishwashers Logo
176 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
