Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Screen is dim/dark picture - Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
  • Anonymous Mar 18, 2014
    Dark or dim picture
Sony Grand Vega 61" HDTV LCD screen going very dim over the past few days...will fade to black with green "on" light blinking, then resets itself to on again, but display still very dim. This TV was purchased from Best Buy in 2005 My warranty expires next June. Is there some adjustment I am missing? Already tried brightness control with little or no response.
Thanks,
Ed
Posted on Nov 16, 2008
Time to replace your DLP lamp!  Expensive ($200 and up)!  Good luck!
Posted on Aug 09, 2008
Screen dims on dark scenes
Melissa check you TV's picture settings, cinema, sports, movie, store, etc.and try a different display setting.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 03, 2016 | Televison & Video
Very dim display..so dark that all I see is a faint picture. Are bad capacitors to blame?
I would say either the video cable has disconneted, causeing the led that lights the screen up to not function,, simpley take the bezel around the screen, take the small screws aroud the screen to slightley pull the screen away from the back top to see if the cable is, or has pulled loose...If now the screen is bad..
Oct 13, 2014 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Green flashing light
the green flashing light does not make sense if set is working.
As far as a dark picture if lamp not replaced or replaced with a generic it may be nearing the end of its life, many will dim just before failing.
Dec 05, 2012 | Mitsubishi WD-60737 60 in. HDTV
Our Lg Plasma 50PC1DRA popped then a very dim picture
If you have the same problem with another input such as a DVD player, this TV might need attention by a qualified service technician.
Aug 05, 2012 | LG 50PC1DRA 50 in. Plasma Television
Picture dims dramatically
I have the same problem so far the best I could do was to put the user setting to sports and brighten up the tv as much possible without making the picture look too bad. Good Luck
Aug 02, 2009 | LG 22LG30 22 in. LCD HDTV
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Compaq Presario Notebook
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 07, 2009 | Acer Aspire 5040 Notebook
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
Nov 19, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
492 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
