Monitor powers up but blank screen cables ok - Computers & Internet
  • alaninternet Jul 31, 2008
    I switch on my PC It fires up then the screen goes Blank, like as if it switches it self off ?
    I've pulled the main electricity lead out left it for a few mins, then plugged it back in to re-start to see if it shockes backn into working, but with no successe. can you help me,
    Regards Alan
    Problem Solver:
  • 26 Answers
The machine has a problem with the VGA or display card. if its on board, try to et another one and if its a pci card ,remove , put it back and start or get a new one.
Posted on Jul 31, 2008
Blank screen
try to connect laptop with external monitor. If works ok something wrong with screen or cable that connect screen with motherboard
Jun 11, 2013 | HP Pavilion dv1000 Notebook
Latitude E5400 screen flickers when external screen connected, extrenal screen OK
Please try to:
check the highest resolution of the external screen then set the resolution of your laptop base on the capacity of the external screen right click on the blank section of your screen then click properties then go to settings choose one like 1024 x 768 press ok plug the external monitor make sure the cable is in proper position then power on the monitor enjoy
thanks for using Fixya
May 31, 2011 | Dell Latitude C400 Notebook
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Desktop screen is blank even when the cpu and monitor indicator a
    It looks like issue with either mother board or processor.
    open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
    Oct 13, 2009 | Dell Computers & Internet
    Monitor will not stay on
    HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
    Jul 02, 2009 | Computers & Internet
    Blue power button flashing with blank screen
    This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
    If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
    Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
    Blank Screen
    Be sure that the power cable and the video cable are plugged into your monitor, the power cable is plugged into a good outlet, and the video cable is plugged into your computer. It's possible that you simply have a loose cable.
    If everything is installed correctly, and if the screen is completely blank (no "cable disconnected" or "test mode" messages), then it sounds like your monitor is simply dead. Since there was a heavy wind storm recently, it was probably hit by a power surge. If you don't already, I recommend that you use a surge protector for all digital equipment.
    Nov 12, 2008 | Computers & Internet
    Screen only stays on for 2 seconds at a time
    just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
    Aug 19, 2008 | Philips 19 in. CRT Monitor
    Can't find video signal
    If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
    If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
    Samir
    PLease rate solution and provide feedback.
    Jun 09, 2008 | BenQ FP731 17" LCD Monitor
    Computers & Internet Logo
    196 people viewed this question
    David Payne
    David Payne
