Evantair heater model EFH2000 stoped working - Heating & Cooling
2 Suggested Answers
  • 1374 Answers
SOURCE: heater stoped working on t5 03 model used to come
Clogged heater core, stuck closed heat valve, defective control head.
Get shop manual if your gonna attempt this repair and a good chiropractor.
Posted on Apr 06, 2010
Why stoped my Cointra 10 gas heater suddenly to heat the water? After about one year we found less water output from the heater, and then the equipment suddenly stoped.
I am not familiar with the model. Is this a 10 gallon water heater? the volume of water can not change. The temperature can usually be adjusted and even placed in vacation mode. Also the pilot light might be out, this would be the only thing I could think of that would stop all hot water. You mentioned output. If you are referring to flow this would be a restriction in you pipes possibly. If you have old galvanized pipes this would explain the reduction in flow. Also if this is a tankless water heater a reduction in flow would explain in not working at all. If the flow of water is not adequate enough a tankless heater will now turn on. If it is a Tankless water heater then there is a filter located on the cold side. To check this turn off the cold water, relieve the pressure by piping the TPRV Valve "Temperature, Pressure Relief Valve. Then take the cover off the filter. clean all that nasty gunk off the filter, reinstall it and you are back in business. The heater should be as good as new.
Apr 12, 2015 | Water Water Heaters
Heater not working on jaguar xtype
if its got a touch screen sounds like climate control module failure had this before try a battery reset
Mar 24, 2013 | 2002 Jaguar X-Type
The heater has stoped working
Year make and model, and what have you checked so far ?
Radiator full of coolant ?
Heater core getting hot ?
Jan 24, 2013 | Cars & Trucks
Broken power switch on evantair oil heater
An Oil heater is not a two way radio...
Peter
Nov 06, 2012 | Heating & Cooling
My heater stoped working checked fuses good thin hit pot hole started working agen but now it stoped agen
Check the connection on the blower motor resistor usally thats the problem with the heater fan.
Jan 21, 2012 | 1999 Pontiac Grand Am GT
Serial#37461 zo1ff73m stoped working
http://www.rinnai.us/customer-support/manuals-literature/ i typed your numbers in but could not get a hit normaly they have good trouble shooting sections. see it you can find a model # that will work
Feb 15, 2011 | Rinnai Toyostove Direct Vent Heater:...
My heater stoped working while driving 2002 cerokee laredo blower works but no heat
Sounds like one of 3 things. It could be low on coolant/anitfreeze, could be the heater control valve not opening to let hot water into the heater core or it could be your heater core is stoped up.
Feb 11, 2011 | 2002 Jeep Grand Cherokee
Heater stoped working on t5 03 model used to come
Apr 06, 2010 | 1986 Volkswagen Wagon Camper
The heater fan stoped workin
Check the blower relay,and the blower switch.
Feb 06, 2010 | 2003 Kia Spectra
My heater blower has stoped working on my peageot
There is a 4" long Green ceramic resistor by the blower motor, prone to fail, I think Valeo does them on the aftermarket.
Nov 19, 2009 | 2005 Peugeot 405
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
