Snapped off Flash Drive
Dear Ekse,
You had just replied to me regarding the my snapped off flash drive and had asked for the make and model. It is a PNY Attache USB Flash drive with 1 GB of memory. I hope this helps.
  • 4 Answers
For "physically" broken drives, we do next-day data recovery for under $100. ($50 for students)
www.24hourdatarecovery.com
Posted on Jul 05, 2009
  • 13,433 Answers
Ok, What you need todo, IF the internal circuitboard of the usb memory is still intact, you will need to solder the 4 usb connector pins onto the usb circuitboard of the usb memory.
This is not your device but you should get the idea, you need to solder those 4 connectors back into place, I marked them with red boxes, if the circuitboard is cracked or otherwise damaged, it may be best to give up. Or take it to a electronics repair man, but if the circuitboard is cracked and there are no good connection points the repair will be very difficult but not impossible.
you need to take the plastic cover off from the usb memory and inspect how the board is, you could even send me a picture here by using the attach picture button.
Posted on Jul 31, 2008
I wanted to format one write protected pen drive
Please confirm the model number of you pen drive so I may help you with a solution.
I will watch for your reply.
Brian
Jan 26, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I had flash drive in my PC and it snapped off, leaving only the USB connector with 4 small prongs sticking out of the laptop. Can I recover this data. HELP!! Thank you.
Usb flash drive? its cut in half, can you tell me what kind of flash memory it is, do you know the brand and model that would help.
Jul 31, 2008 | Computers & Internet
I bent my flash drive and now it don't work
in the end, there isnt much you can do to restore a flash drive, it's small memory blocks, which when bent are capable of cracking, losing all or most of the data stored in them, the rest of the data is corrupted and if your friend messed up sodering it back together (sounds like it SNAPPED) you're not fixing it, short of spending a small chunk of change (around $200) for a data recovery, which is not guaranteed to recover half, if any data. You're best bet unfortunately is likely to buy a new Flash Drive, I hope you didnt have anything vitally important on there... Taxes? School Project? Work reports? yikes if you do and my condolences.
Hope this helped!
Jun 24, 2010 | Verbatim VER95327 USB Hard Drive
Ink lights are not on error UO43
Perhaps one of the ink tanks is not snapped in properly. The cartridge lamps on this model glow red when they are properly seated/installed.
These little red lamps also flash codes:
Slow flash (approx. 3 second intervals) - ink low
Quick flash (every second) - ink cartridge empty
Dec 26, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
Aug 21, 2009 | Memorex Electronics - Others
Drive belt has snapped
Watch this video:
Jul 11, 2009 | Dryers
File system in flash drive is RAW
Please try to reformat it, in order to use your flash drive, & be compatible to store date. regards
May 12, 2009 | Computers & Internet
Write protect usb flash drive on all computers..
Did you have a look at TrueCrypt?
http://www.truecrypt.org/
Jules
Oct 16, 2008 | Computers & Internet
SanDisk won't read
They are typically snapped/glued/molded together. Just have to gently pry at the seams.
Aug 04, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
