Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon PIXMA MX310 not recognized by MS-VISTA on HP Slimline s3321p PC
Have been trying to re-install this printer but USB or VISTA refuses to see it.
Have tried manufacturers recommendations without success. Cannot remember how or why it stopped working now . Very frustrating been down for about 4 weeks. Hope someone can help will send more info if requested, thank you very much.
  • Anonymous Sep 16, 2008
    Same problem with MX318.
    With Vista-home it cannot print, but bale to scan.
    Printer Under warranty, canon technician cannot solve it - say something not right with my PC......software conflict.....etc ..... etc.....
    My PC (notebook) is new, fresh install vista SP1.
    Problem Solver:
  • 5 Answers
Dont buy canon
Posted on Aug 20, 2008
  • Peter Ross Aug 20, 2008
    I have tried all avenues to get info from canon but the service is useless
Canon mx310 printer is offline and won't print from computer
Hi Harry,
Try re-installing the printer again.Disconnect the printer completely from your PC.Uninstall the printers software from your PC and then reboot it.
Insert the installation disk and run setup to install a fresh the printers driver.If you don't have the installing discs,download the drivers from this canon support site.Select the driver that corresponds with your Operating System[Windows XP,Vista etc].
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MX310 All-In-One Printer
I'm trying to scan a document w/ a Canon PIXMA 310. We recently changed computers and might be missing a vital piece of software. I tried to scan to MS Office Pic Manager and to Paint. Neither has an...
What OS are you using? Do you have the full software installed, the Canon driver or the OS generic driver? If you plugged in the USB cable before installing the Canon software, you probably got the generic driver which doesn't run with the scanner. Uninstall the driver and unplug the data cable; then download the software from http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#DriversAndSoftware (select your OS) and install it. Try a new data cable and different port. (Scanning requires bi-directional communication and can fail when the printer works.)
Paint (in XP through Win7) should work if the computer recognizes that the device has a scanner. File > Import from Camera or Scanner. Check your hardware listing. (For Win7 Start > Devices and Printers; older OS versions may have the list under the Control Panel.) The printer might show up twice if installed correctly.
I hope this helps.
Aug 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 won't print wirelessly from laptop. all of network is working except this. pls help. Linksys is the router, Dell running Vista is the laptop, Canon is the printer.
The MX310 is not a wireless printer. I own it and have never seen that feature anywhere in the specs either. Try the MX860 (my roommate owns it and it's VERY nice).
Oct 30, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a canon pixma 310 that I need to
click here
Then download driver for your operating system like xp or vista.
Then connect usb cable of printer to usb ports on computer.
Then install driver from download .
Then it works fine.
Let me know if you need more assistance.
Thanks.
Oct 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I have Vista 32 and trying to install Canon MX310 but getting the message stating that USB device doesn't recognized.
change the usb slot cause its an usb 1.0 and you need a 2.0 for this device ..if ya have the proper driver it has to work ..
Aug 01, 2009 | Canon PIXMA MX310 All-In-One Printer
USB not recognized
the drivers *must* be for Win Vista - not XP.
gurutim
Mar 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Is the Pixma MX310 compatible with Apple's Airport Extreme?
Try to check your cable connection maybe its properly inserted in your port. If it continues to appear try reinstalling your printer. When installing follow the steps in the installation. Disconnect the usb cable to the PC prior to installation. You will be ask to attached it to the PC during installation before completing the installation. Check also your network settings maybe some plug ins are disconnected. After installation it needs also to restart the pc so that new changes of the settings will be detected.
Please rate this solution so that I will have more bases to suggest if you will elaborate on the result.
thank you.
Nov 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Oct 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing to a Canon MX310 through a print server
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Nov 11, 2007 | Canon PIXMA MX310 All-In-One Printer
Connection
Nope, the Canon printers don't come with a USB cable.  You have to supply it yourself.  I just used the one from my previous printer.
Nov 07, 2007 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
90 people viewed this question
old marine
old marine
