Question about ATI RADEON X1650 Graphic Card
Screen going blank for a second or two while video freezes then jumps.
I have recently installed a ATI Radeon X1650 Pro IceQ 512MB DDR2 AGP8X replacing a Winfast 3D AGP graphics card. System requirements for the Radeon are:
At least a 450W PSU
Intel 4, AMD Athlon or compatible with AGP 8x, 4X or universal AGP 3.0 bus
256MB RAM
CD Rom
DVD playback
Windows XP, Windows XP x64 edition.
My System is:
600W PSU (upgraded to suit)
AMD Athlon 64 Processor 3200+
GA-K8N nForce 3 Mobo
2GB RAM
AGP 8X/4X
and the latest drivers I can find for Radeon.
The problem is the screen is going blank for a second or two then coming back. Video starts the freezes but sound continues.
I used to be able to play Age of Empires III on old system although graphis a little slow. Now only get a flash of graphics through the start up screens while sound continues fine and then no graphics for the main screen.
Have played with refresh rates cureently set at 60Hz but have tried all.
Upgraded the PSU thinknig that could be the problem but no change. Uninstalled all previous drivers for winfast prior to installing Radeon. Have tried several uninstalls and reseat of card still with same problem.
Any fixes or suggestions would be appriciated thanks.
  • 781 Answers
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Posted on Jul 31, 2008
ATI Radeon X1650 Pro overheats and videocard shuts down
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
Jun 14, 2009 | ATI RADEON X1650 Graphic Card
Cant get my new graphic card to work
You need to install the drivers. Go to: http://support.amd.com/us/gpudownload/Pages/index.aspx Fill in the fields, download the full package of drivers, and install them. Now your games should work. I hope this helps, Yannick.
Jun 12, 2009 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 512MB DDR2 AGP not detect on my MSI PM8M-V
I have checked you motherboard and the graphics card you mention is supported by your board. See the direct link to the msi website and save it to favourites. http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=205 More help? chris http://www.motherboardsrus.net
Jun 05, 2009 | MSI PM8M-V Motherboard
ATI x1650 Pro Stops!?
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
Oct 17, 2008 | ATI RADEON X1650 Graphic Card
the card you have is a PCI express 16X your board is for PCI express 8X. I think some cards can run at a slower speed but I believe you have the wrong card for your board
Jul 29, 2008 | ATI RADEON X1650 Graphic Card
Graphics cards
Hi noxiney, you're MSI motherboard does have 1 opened AGP 8x4x slot. You can install & run the ATI Radeon X1650 PRO AGP. You can not run PCI-Express because there are no PCI-E slots on the board. There are PCI (White in color) on the board but the AGP slot is much faster than the PCI (White in color slots). The manual states the AGP card can only support 1.5volt video cards & not 3.3volt AGP cards. (Keep this in mind when looking for an AGP card).
Below is a link to a bunch of AGP 8x4x video cards. One or two include DDR2 memory. Carefull where you buy. Check the warranty. (Longer is better). The first one on the list would be compatible. Its not DDR2 but it does have 512MB of memory.
http://www.google.com/products?hl=en&q=AGP+ATI+Radeon+X1650+PRO&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
This card is 1.5v compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3101648&CatId=318
& this is compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1642902&CatId=318
Just remember, if the card can run both 8x & 4x it should support the 1.5volt needed to function on the MB.
Enjoy!
Mike
Jul 08, 2008 | MSI PM8M-V Motherboard
Not getting ATI Radeon 512MB graphics card
Go for :
ATI Radeon X1650 Pro 512MB AGP
ATI Radeon X1600 Pro 512MB AGP
plz rate me if this info is helfull to you... Thanks
May 14, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
The game stopped
Hello matbedui,
If you think the Radeon card is overheating you can check this by simply touching the card after it's been running for sometime. Some Radeon cards (high end) do have this problem. PC cases that do not have sufficient fresh air flow cause problems not just to video cards but to everything inside the case. The design of the HIS Radeon X1650 is less than sufficient. Keeping air flow contained. One way in & one way out. This issue is so important many companies creat sites to help you cool your card.
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=196
Your Radeon X1650 Pro IceQ II runs ATI's chips. Installing the latest software is recomended. Download from here:
http://ati.amd.com/support/driver.html
Pick your OS. Than pick Radeon. Scroll down to your X1600 series. You can also update through HIS. Their software is twice the size of the ATI software.
http://www.hisdigital.com/html/driver.php?id=64
Feb 24, 2008 | HIS RADEON X1650 Pro IceQ II, (256 MB)...
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
ATI RADEON X1650 Graphic Card Logo
320 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
