Question about Canon MV700i Mini DV Digital Camcorder
No picture There is no picture through the lens or on the LCD bt it plays back.
  • 1 more comment
  • Anonymous Oct 29, 2008
    canon MV700i no picture when recording
  • nick 1966 Dec 22, 2008
    every works on the camcorder exept when I switch to camra , no picture or veiwing lens.please can you help?.
  • janetwilkin Feb 09, 2009
    Plays back recordings. Shows text on screen. Can't get a picture.
    Problem Solver:
  • 4 Answers
I had the same problem and Canon repaired my camcorder free of charge. No problems since. Agree with the original solution
Posted on Jun 14, 2010
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It has been found, that in rare case, some of the CCDs, used in Canon digital camera and digital video cameras, have a problem that causes abnormal image output. Free repairs will be made for affected products in cases where it has been confirmed that the internal CCD wiring has come off.
Contact you local Canon Repair Centre
Posted on Oct 13, 2008
No display in viewfinder and LCD
i think you are able too see the video in play back mode. so there is no problem in your LCD.
i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode.
because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
Dec 25, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Describe your Panasonic PV-GS35 Mini DV Digital Camcorder Problem: When I turn the camcorder on in the video camera mode the lcd panel and th evf show black, it does not show current picture to record. All...
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
Oct 18, 2009 | Panasonic PV-GS35 Mini DV Digital...
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
Blank Screen
contact sony via their website, there is a problem with the CCD chip which causes your problem, sony did a free repair to my camcorder.
Jun 21, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
In Camera (Record) mode, does not show video at all, black screen
THIS IS YOUR CCD.. SAMSUNG IS VERY AWARE OF THIS BUT STILL CHARGES A ARM AND A LEG
Feb 06, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
May 07, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Canon MV700i Mini DV Digital Camcorder Logo
323 people viewed this question
Top Canon Video Cameras Experts
KellySD
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
