Philips Freevents X56 laptop won't switch on!
I have a Philips Freevents X56 laptop which is about 18 months old. For the last few months, I haven't been using it every day (I have a new one!) and for the last couple of weeks, I had it plugged in to a surge-protected plug socket. I have done nothing else with the laptop. However, when I went to turn it on yesterday, nothing happens at all.
I've unplugged it, taken the battery out, put the battery back in and switched the power on and again nothing happens.
The green light is on to say the cable is plugged in but other than that, the power switch does not power up the hard drive.
Any ideas of what might have happened?
Here's a link to the model I have http://www.itreviews.co.uk/hardware/h1093.htm
  • 1 more comment
  • technokitten Jul 31, 2008
    Other suggestions I've received so far are:
    * take the RAM out, put it back in. Then turn on again.
    * Try turning on without battery in, only wall power.
    * change plug fuse.
    * use diff plug.
    Take it back to the shop. Ignore what they say about warranties - you're covered under the Sale Of Goods Act for 5 years
    All very useful and I'll be trying each in turn.
    update: when I have the battery in, the green power LED light switches on. When the battery is out but the power is on, there is no LED light.
    Am I right in thinking this suggests the battery is at fault?
  • Surrey Boy Apr 12, 2009
    I have a Toshiba A70 Laptop and it does not start up all the time. Sometimes if I leave it to cool down for a while it will start up, other times it will not. Any Ideas?
Take it back to the shop. The Sale Of Goods Act says that goods have to last for a "reasonable" time. It is not reasonable for a laptop to break after 18 months.
See http://www.berr.gov.uk/consumers/fact-sheets/page38311.html
or search for "Sale Of Goods Act".
It is possible, however, that the power button is broken. Try getting some compressed air to blow out any gunk from underneath it. If the laptop supports it, remove the keyboard any make sure you don't have biscuit crumbs under the key.
Posted on Jul 31, 2008
Could be anyone of a number of things related to internal batteries. Let it charge for a while (does the charging light come on on the laptop? - isn't clear if the green light is on the powersupply or the laptop itself) and trying again.
Remove cd/dvd drive on philips freevents laptop
use a pin on the hole in front of CDROM to open the CD ROM
May 14, 2012 | Philips Brand 12.1 WXGA Glossy Laptop...
Last time used 18 months ago, ran good, no problems. Tried to start it and it won't go...So I checked oil level..(good) removed the fuel bowl replaced old fuel with new fuel all looks well and cle
heat the spark plug for a few minutes then put back in the engine. sometimes works when you not used engine in a long time. it will take a good few goes to get the old fuel out of the carb, the heat helps burn old fuel.
Jul 09, 2017 | Motorcycles
Hello my laptop philips freevents h12y i need audio driver win7
Hi shulalbvvc, "Go to this "Website!"
It shows 'all the Audio Drives for the "Philips Freevents H12Y!"
Scroll down to find:
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.search.philips.com/search/search?h=support&o=support&q=Audio+Drivers+Windows+7+philips+freevents+h12y&f=all&i=all&language=&l=us_en&s=all&n=10&d=&p=&p_fld=&p_val=&highlighted_param_entry=¶m_group=¶m_group_value=&first=&last=&next_start_hit=11&bannercount=0
Mar 16, 2011 | Computers & Internet
How many memory slots does the philips freevents x56 laptop have?. i can only find one.
Yes most laptops only have one but you can use your SD card it in, this also includes using micro adapters as well.
Dec 30, 2009 | Computers & Internet
Recovery disk for Philips Freevents and system running slow
Readthis thread before you attempt anything.
http://lofi-gaming.org.uk/blog/2008/02/29/how-to-install-xp-on-a-philips-freevents-11nb5800-laptop/
Aug 02, 2009 | Computers & Internet
Need to replace keyboard on Philips freevents x56
There is one screw holding the keyboard in from the bottom - remove this, unclip the 4 clips across the top with a bank-card etc. and you're away. Remove the ribbon, Replace, and reverse for re-assembly.
Jun 30, 2009 | Computers & Internet
Philips Freevents X50 charging problems
well my friend I hate to say this but the problem is in the motherboard, and the motherboard should be replaced.
Jun 27, 2009 | Computers & Internet
How do you go back to factory settings on a philips freevents x51 laptop?
If you cannot find the backup disks an option that you can do is system restore although it really depends on how long your last restore point is.
Go to start then run then type in MSCONFIG
after that click on Launch System Restore
Restore it to the oldest date. Luckily it will have the system checkpoint at the first time you used it.
Nov 08, 2008 | Computers & Internet
My philips freevents x56 keeps overheating
try to clean the cabinet for dust and check if the cpu fan is working properly.
hope what helps.
CS.
May 16, 2008 | Computers & Internet
Computers & Internet Logo
969 people viewed this question
David Payne
David Payne
