Question about Canon L120 Fax Laser Printer
Storing FAX numbers in Canon FAX-L100
How can I store FAX numbers in FAX-L100 to quickly send faxes to commonly used numbers.
Many thanks,
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Jul 31, 2008
    New Friend:
WHEN i WANT SENT FAX MY FAX MACHINE IS RINING RHEN CUTS OFF
Posted on Jan 21, 2014
Need to know how to fax from mcf 210c
How to enter Fax mode
Before sending faxes, make sure (Fax) is illuminated in
green. If not, press (Fax) to enter Fax mode. The default
setting is Fax.
How to dial
You can dial in any of the following different ways.
Manual dialing
Press all of the digits of the phone or fax number.
Setup Send
3 - 2 SETUP SEND
Speed-Dialing
Press Search/Speed Dial, #, and then the two digit Speed-Dial
number. (See Storing Speed-Dial numbers on page 5-1.)
Search
You can search for names you have stored in the Speed-Dial
memories. Press Search/Speed Dial and the navigation keys to
search. (See Storing Speed-Dial numbers on page 5-1.)
* To search alphabetically, you can use the dial pad to enter the first
letter of the name you are looking for.
Fax Redial
If you are sending a fax manually and the line is busy, press
Redial/Pause, and then press Black Start or Color Start to try
again. If you want to make a second call to the last number dialed,
you can save time by pressing Redial/Pause and Black Start or
Color Start.
Redial/Pause only works if you dialed from the control panel.
If you are sending a fax automatically and the line is busy, the MFC
will automatically redial one time after five minutes.
If the LCD shows Not Registered when you enter the
Speed-Dial number, a number has not been stored for it.
Color fax transmission
Your MFC can send a color fax to machines that support this feature.
However, color faxes cannot be stored in the memory. When you
send a color fax, the MFC will send it in real time (even if Real Time
TX is set to Off).
Nov 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
On our cabnon l100 we are trying to send faxes. After entering fax no. we are getting message saying *Memory* Set Doc - but fax does not go - what have we done wrong?
try to check the memory of your fax, their might possible that the memory is full and need to clear them. Just a thought hope it helps thanks.
Sep 15, 2011 | Canon FAX-L100 Plain Paper Laser Fax
I have a 25 page document that must be faxed to several different numbers, on a daily basis. Is there a way I can fax the document to multiple numbers at one time? I am using a Canon Laser Class 2050 P -...
You can't send a fax to more than one number at a time since each fax call needs to be placed separately. But the machine allows you to automate the process by storing the numbers in speed dial as a group, and then sequentially sending the same fax to each of those numbers for you. Full details are in chapter 6 of the manual (available here if you need a copy).
Mar 24, 2011 | Canon Office Equipment & Supplies
My work canon jx 300 is storing faxes. Auto print
Press MENU and # - this is service mode.Find CLEAR, and OK, then select clear ALL. After that fax returns to factory sett.
You will need to reenter your settings, but it should work.
Jun 24, 2010 | Canon FAX-JX200
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
Canon JX200 printout
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=338&modelid=14787
Try these user guides, but I don't think that the fax is capable of storing each fax that it sends. If you need a copy of said document, you might have the person fax it back to you. Hope this info helps.
Aug 18, 2009 | Canon Office Equipment & Supplies
Canon-l100-fax
Under user mode (MENU), there must be something like user sett.
Feb 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Aug 18, 2008 | Office Equipment & Supplies
Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
May 19, 2008 | Canon FAX L-120 Plain Paper Laser
Canon Fax L120/L100
press menu and then # goto service mode. Select the clear data function.
Clear all the memory, dRAM and counter.I hope it will work for you.
May 10, 2007 | Canon L120 Fax Laser Printer
Canon L120 Fax Laser Printer Logo
385 people viewed this question
old marine
old marine
