Question about IBM NetVista PC Desktop
IBM Netvista desktop bios problem
I have a IBM Netvista desktop and under bios settings, i am unable to get first boot device option. I have reseted it still no luck. I have formatted the hard drive and unable to boot it now....Please help me out to resolve this.
Nitin Lal Windows xp is not being installed...anyway...
  • 1 more comment
  • mani9786_obm Dec 02, 2008
    please give me solution for this problem
    with out xp it won't ever load into windows again. putting a cd in the tray should auto load it.
  • Klutch Davis
    Klutch Davis May 11, 2010
  • 781 Answers
This is more like a workaround that I used on a laptop which cd room drive just failed (and which I did not want to replaced as it was more expensive than the whole laptop)
If you can't select the device you want to boot from.. you may want to partition your hdd and format it so it loads a dos operating sytem .. use another machine and a win98 startup disk to do this then copy your I386 folder from your winxp cd into the new formatted hdd so when you put the hdd back into the IBM machine it loads dos and then going into the I386 folder you can run a winnt command for you to install the os.
Posted on Sep 20, 2008
Unable to boot from cd or floppy, goes right to os(XP), bios Is In french and I cannot find boot order. How can I change bios language from french to english?
try to reset the bios reseting your bios will restore it to its default setting, then reboot again check if the laguage has been change
Nov 23, 2009 | IBM NetVista A21 PC Desktop
Ibm netvista bios language changed. japanees lang. displays on booting. pl.help
remove the bios bettry and refix it ...... it will set the defult setting (company setting...)
Oct 29, 2009 | IBM NetVista PC Desktop
Ibm not boot from usb
When the system starts up there is usually a key to hit for SETUP, usually ESC, F1, F4, or DEL
Find it, and hit it at the right time.
You will enter the CMOS or BIOS setup.
Once there, locate the BOOT SEQUENCE section and allow a USB boot or external component Boot to be placed int he sequence it it MIGHT work.
Not sure what you're trying to boot from USB for.
Oct 19, 2009 | IBM NetVista M42 PC Desktop
Unable to boot
hello there!
Depending on what system is, you (BIOS) usually you press a sequence keys, like DEL, PF10 or PF11 when system start, usually IBM models is ESC key to go on BIOS.
Open Sky
Jul 24, 2009 | IBM NetVista PC Desktop
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Mar 06, 2009 | IBM NetVista A40 PC Desktop
Not seeing a option to boot from cd rom
In the boot sequence you have to set the cd drive as the first bood drive.
Jan 11, 2009 | IBM NetVista PC Desktop
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
First of all if you re formatted the drive You have lost ALL of the information on that drive. Next you don't need to go through BIOS in order to boot from a disk. You can press F8 on the screen that you would normally enter BIOS with.
Hope This Helps
All The Best,
RCF
May 28, 2008 | IBM NetVista A40 PC Desktop
How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
Aug 26, 2007 | IBM NetVista A40 PC Desktop
IBM NetVista PC Desktop Logo
256 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
