Question about Bugaboo Cameleon Jogger
Hi, my sun shade is sagging where the logo section is. i have tried all ways to fix this and even looked at other ones instore. i seem to have placed this on correctly however it still wont sit firmly. please help....
  • 419 Answers
This sounds like you have your sun canopy clamps on the wrong way around. Simply swap them over and the hood should function normally.
Hope this helps.
Posted on Apr 03, 2010
I have a Dream On Me Mia Moda Compagno Sit and Stand Stroller color:MINT JAVA . The sun shade was lost while we are moving . I want to know where can we buy that part
contact the manufacturer or an authorized service agent or places like toys -r-us for possible places to get the item
Oct 27, 2015 | Dream On Me Baby Gear
Cant remember how to refit the sun shade
The sun canopy has a length of elastic at either end with a turn-over that is stitched in place. These lengths of elastic need to be pushed past a nub of plastic inside the sunshade rim around where the handle of the carseat is joined. Pull them past the nub of plastic and release, and the turn-over will prevent it popping past the nub. Tuck in the sunshade around the rim.
Oct 18, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
How to operate sun shade in toyta avalon 2006
try this , it shows you the general area of the switch. There seems to have been problems with them though. I would also check the fuse and the switch itself. If all are ok there is a good chance it's the motor for the shade. http://www.bing.com/videos/search?q=how+to+operate+the+sun+shade+in+a+toyota+avalon&FORM=VIRE1#view=detail&mid=F6516CB571872653F0CDF6516CB571872653F0CD
Jun 28, 2012 | Toyota Avallon Cars & Trucks
Hi I'm Peter. try this , it shows you the general area of the switch. There seems to have been problems with them though. I would also check the fuse and the switch itself. If all are ok there is a good chance it's the motor for the shade. http://www.bing.com/videos/search?q=how+to+operate+the+sun+shade+in+a+toyota+avalon&FORM=VIRE1#view=detail&mid=F6516CB571872653F0CDF6516CB571872653F0CD
2002 Bonneville Sunroof. Fabric on sunshade was loose, was able to pull shade forward, glued fabric but the shade will not go back. Seems to be hitting something in the back. Can you help?
Hi
Inspect the sun roof of your Pontiac Bonneville to make sure it's seated evenly on your vehicle, not raising or lifting at one corner. Lifting indicates the presence of debris on the tracks, or a damaged seal around the sun roof.
Remove the trim on the interior of your Pontiac Bonneville and allow the interior material to drop. Use compressed air to blow dust and debris from the tracks that move your sun roof. Treat the tracks using 3-In-One Lubricant.
Check the Pontiac Bonneville's drain tubes for clogging. Two of these run down the front of your vehicle to the bumpers. Two run to the back, most often by your tail lights. Clear the tubes using compressed air and replace them.
Clean the sun roof's rubber seal with a damp, lint-free cloth. Inspect the seal as you clean
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 19, 2011 | Pontiac Bonneville Cars & Trucks
Hi..Im looking to get my 2011 KX450F suspension working right for my weight of 70kgs The forks seem way too harsh/choppy over small bumps at speed..doesnt help with arm pump much..lol.. .....Wanted to...
Your going to have to keep working through the manual, it has way more info than can be typed here.
If it feels too hard and youre out of adjustment, you need to try a softer spring.
you can try anything that works for you, forks up, down, more or less sag, there is no quick simple fix and what one rider says is good may not work for another, and a different track may change things completely.
harsh front- reduce the compression damping, high speed or low speed depending on how far the forks are compressing or lighter oil, if you go too light it may try to tank slap and need a steering damper.
If you use all the travel, then the springs are close to correct, it can even bottom out a little on the biggest jumps
One step at a time and take notes of each change, including how it felt and what the track was like.. this is the way to see what works, and give you the option to easily change it back if it doesnt
May 23, 2011 | 2010 kawasaki KX 450F Monster Energy
I am looking for a shade for a fan with owner manual # m-dig-03 IM-KMCM2
Not sure I understand the model you are looking for, but what you need to do is get the measurements and search. This is one URL I found that could help you.
http://www.bizrate.com/lamp-shades-bases/ceiling-fan-shades/
You can also look at the Home Depot or Lowes. Worst case you can replace all of the globes as opposed to trying to match one or two you already have.
If this information helps you in any way I would appreciate you rating me in the Thumbs Up section of FixYa. If I can help in any other way, please feel free to contact me.
Paul
Sep 22, 2010 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Glass replacement for Hunter fan
Hi, hunter fan glass replacement can be found at amazon, take a look here and chose: Amazon com hunter fan glass replacement. Regards. Donald
Jul 10, 2009 | Dryers
1998 Audi A6 sunroof is will close only half way.
make it go back to the open position,look down the side of the tracks in the roof that the sun shade slides in and you will probable find the guides for the sunshade are jamming up the tracks. only way to replace them<4 one in each corner> is to remove the glass section and then close sunshade that will give access to the 4 guides which are available from dealer as a kit
Mar 24, 2009 | 1996 Audi A6
Sun shade / mosquito net doesnt stay attached!
Hello trollmor:
These are great questions. The mosquito net elastic loops are going to be fastened around the hooks under the canopy. In order for it to work properly, the elastic hooks that hold the canopy in place need to be removed and the elastic loops for the mosquito net and sun shade will take their place. The elastic should hold both shades in place properly.
If this does not work, please feel free to email me at strollerinfo@gmail.com.
Sincerely,
StrollerInfo
www.StrollerInfo.com
Jun 19, 2008 | Bugaboo Cameleon - Tailored Fabric...
Bugaboo Cameleon Jogger Logo
282 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
