Question about Lexmark Office Equipment & Supplies
Lexmark printer will not install. Error light keeps flashing,although printer has previously worked with the same computer.
    Problem Solver:
  • 26 Answers
How many lights ae there and if more than 1 which one??
It might be having a catridge error or a paper jam.
If it cnt install using the cd application software, just install its drivers only and see if it will accept.
Plug the printer to the PC and also insert the software cd. If the cd auto runs, cauncil it and look for the new hardware message and install the printer via that route, if not sure how, get back to me.
thnx
Posted on Jul 31, 2008
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
I cant get my 4650 to scan it keeps saying downloading application list but it never does anything
If you are scanning documents to edit or save as PDF file, you will need to install the OCR scan software on your computer. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If scanning from your printer to your computer was working previously, then it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected) > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to scan again once the computer fully recognizes the USB connection (if USB connected). If printer is connected wireless, wait until the WiFi light on the printer turns on solid green before trying to scan a document.
Dec 28, 2011 | Lexmark X4650 InkJet Printer
Just installed new printer Lexmark E260dn all lights flashing- printer does not print
This light sequence means that the printer has a service error, and printing has stopped.
Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer.
For further assistance, please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark E260dn Laser Printer
I am unable to uninstall my lexmark printer driver from my laptop... i was trying to install the new driver and it refused to over ride the previous installed driver and then i did a system restore and now...
Please try this. Run the install disk/web installer -> select Support -> select Uninstall. If Uninstall initializes, reboot your computer after the process finishes. Then reinstall using the new driver.
If the "Uninstall" option is not available, it would be best to contact Lexmark technical support for assistance.
NOTE: MAKE SURE TO USE THE PRINTER DRIVER COMPATIBLE WITH YOUR COMPUTER'S OPERATING SYSTEM.
Nov 11, 2010 | Lexmark X2550 All-In-One Printer
Trying to install my Lexmark Z600 printer on my new Dell Inspiron desktop. It worked fine on my old computer. I have the CD and have installed it and, in the setting up process ticked Lexmark Z600. I...
bordermec is right - If you didnt install it correctly you may have to remove the software and start again.
Although it sounds like you dont have a good connection bet the PC and the printer. Double check that as well.
Oct 30, 2009 | Lexmark Z600 InkJet Printer
Error Message on Printer
your printer driver is not vista supported or motherboard driver is not properly instaled
May 29, 2009 | Lexmark X5270 All-In-One InkJet Printer
Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
  1. Turn the power OFF.
  2. Open the front cover.
  3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
  4. If it does not, close and reopen the cover:
  5. Remove the color print cartridge.
  6. Close the cover.
  7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
  8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
  9. Remove the black print cartridge and reinsert the color cartridge.
  10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
  11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Ink light flashing
whip the cartridge circuits with the tissue paper, if the problem occurs the same thing than this is the service station error mean s the software has to be installed again
Mar 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
