Question about Whirlpool Duet GHW9150P Front Load Washer
F28 ERROR hello i have a front loading whirlpool washer it has a error the error is F28 and the front door will not unlock can some one please help my email is lts_1@msn.com thank you
  • Anonymous Mar 18, 2014
    error f28
Remove the bottom front panel. Three 1/4 hex screws. Use a flashlight, look insde on right side about door level. You should see a clear or white pull tab. Pull the tab gently and you should hear the door click. This should resolve your problem, it did for me.
Posted on Sep 14, 2008
I have a Kenmore Elite that has done the same thing, I had to press power and then start (to start a new cycle) then the stop/cancel button and this unlocked my door. Power and then cancel/stop just turned off the power again and did not unlock the door. I hope this works for you.
Posted on Aug 09, 2008
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool f28 error code and door lock light
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
Washing stops in cycle with an F28 code.
Hi
This code indicates an electronics communication problem with the washer.Please check this link to get a detailed idea related to the lists of codes and the resolutions to them:-
http://whirlpool.custhelp.com/app/answers/detail/a_id/2885/~/display-shows-an-error-code---front-load-washer
The error code F28 means one or both of these parts are bad.
Motor Control Unit ,Microcomputer Machine Control Unit .
It would be a good idea to order both, as both components have been problematic for error code F28.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | Whirlpool Washing Machines
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
F28 code
Thank you!!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
I am getting an F28 error on my front loading whirlpool washer
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 26, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F28 error
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
308 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
