Question about Hotpoint Washing Machines
My washer WT740 (Hotpoint) is showing the door warning light. This has only happened since I selected a different wash from the probram. The door operates ok but I think it needs resetting. How do I reset the start and on buttons to default please?
  • 30 Answers
Hi you can download a manual (free) from hotpoint it will tell tuo in there.
Posted on Aug 06, 2008
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi i have a hotpoint washin machine and it kepp showing H20 on the csreen can you please help th model number is WT740
H20 indicates a problem with water supply.
Check the inlet hose/s for restrriction or kinks, ensure water supply pressure is o/k, also check the filter screens in the inlet valves, you will have to turn the water off to do this.
Dec 06, 2010 | Hotpoint Aquarius WD63 Front Load...
I cannot open the door on my Hotpoint Aquarius wt740 after it finished a wash. Door handle is floppy and door light is off.
it sounds like you have a broken door handle Disconnect power before doing anthing remove lid , what you will need to do is usining a screw driver or somthing simular look down to where the catch is (you may need a tourch) and look carefully you should be able to to the door catch mechanisim from inside you will need to mimic the action of the door handel but using a screw driver it a bit fiddley but can be done there is no grate force needed and it the catch will only need to move a bout 3-8 mm to open
Jan 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code H20...My washing machine, a hotpoint wt740 is showing the warning light H20...does anybody know what this means? thanks
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Dec 24, 2009 | Washing Machines
The start button on my hotpoint wt740 washing machine wont click on.
Hotpoint had a problem with a control panel design where if the start button is pushed too hard, it snaps off the panel. This is most likely cause but it might be a faulty door lock.
Dec 09, 2009 | Hotpoint Washing Machines
Fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
May 24, 2009 | Ariston Technologies Washing Machines
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Hotpoint washer WT740which is 2.5years old has this am refused to wash. It will draw its first amount of water and then does nothing . Having cancelled the program (F) I tried to get it to fast spin but...
Hello bennff,
2.5 years old from manufactures date or bought used???
Is this the correct model number found , ON THE WASHER?
It is not showing up in my repair search.
Where did you buy this washer?
Oct 16, 2008 | Washing Machines
Washing Machines Logo
336 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
