Temp/fan light problem,
Hi...  PLZ Help For sony projector vpl-sc50m
How to Stop light.....
  • 6 more comments
  • Xtr33m3 Aug 11, 2008
    I have the same problem with my projector. the unit will turn on fine and the fan speed will increase in steps until the unit finally shuts down.
    I have tried cleaning the airfilter and have determined that the unit is indeed pushing through a good amount of air, however it has not resolved the situation.
  • jamesmeacham Aug 20, 2008
    I have the Sony VLP - EX3.
    The unit turns on fine, but after a few minutes the fan sound like its accelerating then the screen turns off and the temp/fan light stays on a yellow colour.
    Please can anyone advise what the cause is and the resolution.
    J
  • francinehad Aug 21, 2008
    I have a VPL HS2 Sony projector with the same problem. It had the problem once, then another day started working again and now problem has come back.
    What is the reason and the solution?
  • aperez2232 Sep 26, 2008
    The lamp dont turn on and the fan/temp light are on
  • Anonymous Dec 12, 2008
    I have a temp, fan error upon start up. unit will not power up.
  • Anonymous Feb 19, 2009
    THE PROJECTOR ARE OVERHITTEN. PLEASE STOP.
  • danacreative Feb 21, 2009
    When powering up after about 5 seconds the temp light comes on and the unit shuts down.
    Temp light comes on and will not complete start up
  • babybentley Mar 16, 2009
    Right after startup, the temp light comes on and the projector shuts off.
  • 10,594 Answers
Does it still in trouble? because I got your post today.
Posted on Aug 02, 2008
How do stop high temp in sony VPL-DX140
Clean the air filter
Don't run it at ceiling height in a very hot room with no ventilation.
Sep 10, 2014 | Sony VPL-DX140 Projector VPL-DX140
I have a vpl-cx10,it starts up and the fans all run for about 3 sec. then i hear a click and it shuts off and the fan/temp light comes on. can anyone help???
hi,
Do one thing just reset the lamp hour of you projector. For that do the following
Press the following keys on the control panel in the following order for less than five seconds each
RESET , Left arrow button , Right arrow button, Enter. Remember one thing lamp hour reset is recommended only after replacing the lamp.
if it doesn't help then the lamp of your projector is faulty you have to replace the same.
ok
Mar 31, 2011 | Sony VPL CX10 Multimedia Projector
Press the power button to switch it on, the sony logo lights up and it switches on as per normal operation, it then switches off after a few seconds and the temp/fan light flashes
hi,
may be your projectors lamp colling fan have some problem. may be it is get jammed due to dust or it may be faulty. without fan the lamp will get over heated. that's why the temp/ fan lights flashes.
jus check it . need further help feel free to contact.
ok
Dec 20, 2010 | Sony Projector Lamp for VPL-HS51
Hi I have a problem with my Sony VPL-CS4 LCD Projector. The problem is, when turning on AC the LED's: LAMP/COVER and TEMP/FAN turns on blinking, and consulting the torubleshooting section of the manual, it...
Attend to the issues. Lamp cover may mean the cover is not fitted correctly or the switch is faulty like wise the fan issue may mean no rotation so it will not start.
Nov 06, 2017 | Sony VPL CS4 Multimedia Projector
When the projector is turned on, the green light
Sir it seems air in out problem.Clean all air filter or open lamp cover and give air pressure using with air blower or vacuum cleaner
Feb 25, 2010 | Sony Cineza VPL HS2 Multimedia Projector
Tel me plz the default service mode ,of Sony projector vpl-es3
Hi there. To Service Mode in SONY VPL-ES3 is, ENTER-ENTER-LEFT-ENTER. watch out!!!, Don't change anything if You don't know what are You doing.
Nov 25, 2009 | Sony VPL-ES3 Multimedia Projector
Power up
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
Apr 24, 2008 | Sony VPL CS2 Multimedia Projector
Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Mar 14, 2008 | Sony VPL CS1 Multimedia Projector
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Temp/fan light
Urjant.....
               Reply...
Feb 27, 2007 | Sony VPL SC50 Multimedia Projector
1,287 people viewed this question
jasbo
jasbo
