Question about Samsung V20 XVC 2400 Notebook
Screen Keeps dimming and contrast function does not work
We have a samsung np r40 plus, its not very old and we have had this problem since getting the laptop...the screen dims and we cannot see much of the screen sometimes its fine and sometimes not...we have tried changing the optimise for performance etc and have also tested that its not as a result of the battery running out....any ideas what might be wrong or what setting needs changing?
  • CAYLEM00 Aug 01, 2008
    Thanks very much for all your suggestions, I will work through and check each item -I do know that the function key for the brightness does not work when the screen dims at all so maybe its another one of the problems you have detailed...thanks for the speedy reply too
  • kevfar65 Aug 20, 2008
    I have a broken ac / dc socket on my samsung v20. I have a replacement however when I try to split the back off I cant get one side to budge. I have taken al the screws out I can see, even the one under the flap. ANy ideas
    Genius:
  • 1,019 Answers
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Posted on Jul 31, 2008
Samsung r40 reset to factory settings
hello there Start by pressing F4 when the BIOS "Samsung" screen is showing. This will allow you to restore the original operating system from the recovery partition, if is there. (Also try the other Fn keys - F6 and F8 may do something).
Otherwise you will need to beg, borrow or buy an XP Home installation CD and use that for a new installation. You can use the Samsung key on the bottom to activate it. You can get the R40 drivers from SamsungPC.
Feb 12, 2013 | Samsung NP-R40 NP-R45 NP-R65" (CL102791)
Samsung notebook screen turned sideways
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
May 11, 2012 | Samsung NP-NC10-WAS1US Notebook
HOW TO REMOVE OLD CD-RW FROM SAMSUNG NP R40
  1. JUST SWITCH OFF YOUR MACHINE AND TAKE OUT THE TOWER COVER AND UNSCREW THE CD RW FROM THE TOWER.
Oct 28, 2009 | Computers & Internet
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
1. Press [2nd] key and release it.
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
To lighten the screen
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
My TI 84's screen went black.
One possible solution is to dim the screen contrast. To do this, turn the calculator on press the 2nd key, then the up arrow. If contrast has been darkened, this should work. To darken the screen if you get it too light, you do the same, but use the down arrow. Hope this helps.
Oct 01, 2009 | Texas Instruments TI-84 Plus Silver...
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
Samsung r40 plus laptop
increase the brightness from the BIOS Screen.
Aug 24, 2008 | Computers & Internet
Samsung V20 XVC 2400 Notebook Logo
643 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
