Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
LCD Touch Screen
Hello, on our cam the touch screen quit functioning - we tried the recalibration as suggested by the manual, and iot moved the "x" on the screen, but the screen still doesn't work. HeELP!!!
Thank you :)
  • 10,594 Answers
Connecting flexible wire between LCD and main board of camera seems cracked/ broken. Please replace it with new one.
Posted on Jul 31, 2008
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 660 touch screen dosen't work
  3. Touch Display.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen activates wrong option
try calibrating the screen, its most likely in the tools section, but if the screen is messed up like that then
you may have a hard time getting there.
Apr 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
How do you recalibrate the touch screen on the Quantum XL-1000?
Enter service mode....
Press the start/stop switch and hold it while you power the machine on.
THEN, press the reverse switch, hold it and press the lcd. Release the reverse switch AFTER you touch the LCD.
Nov 15, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Touch screen on my Garmin Nuvi 660 just stopped functioning
If after a calibration the screen fails to respond then its the scrapheap i am afraid The cost of fix exceeds the value to replace
You could try a claim on insurance to have it replaced, especially if it was accidently dropped
Jul 25, 2009 | GPS
Touch screen not working
Try recalibrating the touch feature. Touch screen devices need to be recalibrated ever so often. The more it is used, the more often recalibration should be done. I recalibrate my LG VU once a week. Hope this helps.
May 22, 2009 | LG KU990 Viewty
Touch screen problem
Please see the solutions on the same model I posted earlier
Nov 01, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
DS Lite touch screen
try to recalibrate the touch screen.
turn on your DS
go to the SYSTEM OPTIONS
last available box, recalibrate.
i may be wrong, but try that anyways.
Oct 21, 2007 | Nintendo DS Lite Console
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
180 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
