Question about Compaq Presario 700 470024-192 Notebook
No pwer dear sir and mam,i disassembling the entire parts of my laptot and then when i close back again,there is no power anymore.any one can help me
Try disassembling the entire parts of your laptot again, 'm sure that would help
Posted on Aug 04, 2008
Hello konica 7255 with error message sc36-02 how can clear this?
Sir/Mam,
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Jul 27, 2016 | Konica Minolta Office Equipment & Supplies
What is error code 3502
Sir/Mam,
The fusing unit is causing the error. that part that gets hot. The code is stating its getting to hot. When was the last time a Preventive maintenance was done every 250,000 copies certain parts are to be replaced. You can try reset power off (Main Power Sw is inside) Sub power is on the op panel try leaving the sub on then power on with main close door once on keep the utility button down) the machine hold the utility /counter button down power on the machine wait to you see trouble reset. touch it see OK then power off wait ten seconds power on. IF the code comes back do not reset again the machine is telling you its broke this section of the machine can get hot enough to burn!!!!!! Get a technician out to fix it and conduct a PM remember every 250K and replace drum 500K
Jun 30, 2014 | Konica Minolta Bizhub 600 750 Image...
Minolta 451 erro 3-b04
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! hope this helps
Oct 23, 2013 | Konica Minolta KONICA BR BIZHUB C451...
Sir/Mam, I had purchase Sony
Has it been dropped? I had a cabera that was dropped and the lense would not go all the way back in which caused the lense covers to not close.
Oct 22, 2013 | Sony Cyber-Shot DSC-W570 Digital Camera
How to reset error code c-3803
Sir/Mam,
POWER off the machine Main power switch is inside the machine. Keep the sub power switch on one located on the side of the control panel. Now hold down Utility/Counter button and turn on main power close cabinet then wait for trouble reset Touch it get OK then power off WAIT TEN SECONDS then power up IF IT COMES BACK DO NOT RESET IT. IT IS BROKE AND MACHINE IS TELLING YOU THAT. THIS CODE deal with the FUSER (Hot part) Can catch fire!!!!!!!!!!!!!!!!!!!!!
Apr 30, 2013 | Konica Minolta Bizhub 600 750 Image...
Dont turn on bizhub 500
Sir/mam Power off the machine including the one inside the machine. Now with the machine completely off turn on the sub power switch that's one near the control panel, now hold down the Utility/Counter switch and turn on the main power switch then close door keep you finger on the counter button when the screen shows trouble reset touch it goes to OK then power off wait ten seconds before power on. If it comes back get a tech to look at it do not reset because you are dealing with fuser the hot part could catch on fire and that would ruin a perfectly good day.
Jan 11, 2012 | Minolta Office Equipment & Supplies
C3452 error code bizhub c352
Sir/ Mam,
If after this procedure the code comes back do not reset again, get a tech out and expect to pay for a new fuser unit, continue resetting can cause the fuser the hot part to catch on fire ruining a perfectly good day.
1. Turn OFF the Main Power Switch (Located in side front cover). (ensure Control panel power switch is on)
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Jan 10, 2012 | Konica Minolta Office Equipment & Supplies
C-3725 trouble code
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. It will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
May 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Printer is showing error c3725 and offline. Can you please help
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit.. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Mar 12, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Polarid 32inch lcd
I don't have a problem to the solution,but my tv is not working it wouldnot comeon it appears that polorid has a problem with the pwer supply
Jun 12, 2008 | Polaroid FLM-3232 Television
Compaq Presario 700 470024-192 Notebook Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
