Question about Kirby G5 Bagged Upright Vacuum
Kirby G5 intermittent power
The vacuum 'turns off' intermittently unless held nearly parallel to the floor. If not held in this position and moved very slowly, it will shut off, then quickly turn back on, then off again. Sometimes it is hard to get it to turn back on (have to find just the right angle), but I never have to push the power switch. The switch remains on, but the motor itself stops/starts.
Any suggestions? I would like to order the necessary part(s) and fix this before causing further damage to the vacuum.
Thank you.
  • 357 Answers
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Posted on Aug 28, 2008
I was sweeping my floor I turned it off, then when I went to turn it back on it wouldnt turn on? HELP
Check the power button switch, it is often cause vacuum to shut off. Thus cutting current flow into the vacuum circuit. Also check the cord for intermittent connection. The cord is subjected to bent, twist and other abuse action while vacuum is in use.
Good luck.
Jul 17, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby intermittent power, sparks near foot switch, how do you remove switch? Coud just be a loose connections?
lay handle down toward floor and remove case top screws and replace the switch you'll be money ahead
Sep 27, 2009 | Vacuums
I have a Kirby G5 vacuum that when light pressure is put on the handle it moves forward but in a jerky movement. Like the drive is engaging and disengaging. If you keep forward pressure on the handle the...
I hope adjusting position of the position of the "pivot spring assembly" will help. but you may have to disassemble entire slide assembly to clean it up if it still does not work smoothly. See instructions HERE (adjustment is explained in step #6). Try to "play" with screws #4 and if it does not help - clean slid.
Good Luck
Feb 28, 2009 | Kirby G5 Bagged Upright Vacuum
G5 intermittently or not at all pulling up dirt
Turns out that little light is a BELT indicator. Even though the belt wasn't broken it had stretched and needed to be replaced. So a $2 part and my baby is working as well as ever!!
Jan 17, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Techdrive pedal
Kirby N/D pedal is an assembly that can not just come out. So I would say that it is most likely broken. See THIS ITEM and if the part that was left on the floor is just a part of what you see in the picture then it is broken.
It is possible to assemble it back together but usually it falls apart again fairly quick and it is hard to get the angle at which pedal must be reassembled. We usually do not mess with it.
Good Luck
Aug 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 vacuum
check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5
The transmission needs adjusting. Just a little fine tuning. See if you can find a repairman near you, or you can contact us at 1-866-509-1952. Thanks
Jun 16, 2007 | Kirby G5 Bagged Upright Vacuum
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Kirby G5 Bagged Upright Vacuum Logo
197 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
