Question about Epson Stylus C42UX InkJet Printer
Faults my printer epson c42 ux is constantly printing previou data ? what do i do Yours Sincereley jim
    Novelist:
  • 110 Answers
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
T
ry Printing
Posted on Aug 22, 2008
I have lost instalation disk for the epson stylus c42 plus printer how can I install
I also have lost  the installation disk for my epson stylus c42 plus printer please could you advise me what to do.
May 21, 2010 | Epson Stylus C42+ InkJet Printer
Epsn C42 No Yellow
The ink path is probably plugged. Try getting some ink cleaner and a squeeze bulb to purge the path IN the printer by forcing cleaning fluid into the yellow channel (cartridge removed). After it flows, it will likely take a bit to get the yellow flowing. If you have a refill kit, you could "encourage" the flow with it. Nothing you can fix by cartridge, the problem is in the printhead.
Aug 21, 2009 | Epson Stylus C42UX InkJet Printer
EPSON STYLUS C42UX PRINTER.
You say you have downloaded the SSL utility. Install it and right click the ssc icon in the system tray (bottom right corner of the screen). Select reset protection counter. This will restore your printer to a working condition.
Oct 05, 2008 | Epson Stylus C42+ InkJet Printer
Epson Stylus C42
Click on start, control panel then double-click printers and faxes. Double click the printer icon and you will see the printer queue. Click on Printers then Cancel All Documents. When all documents are gone from the print queue, restart your computer and switch your printer on. Click on start, control panel then double-click printers and faxes. Right click the printer icon and click on Properties. Click on Test Print. Check the print is OK. If not, report back.
Sep 23, 2008 | Epson Stylus C86 InkJet Printer
Epson stylus C42 plus
this is for windows xp
start-settings-printers n faxes(click on it)-right click on your printer name - click on properties(below)-printer properties dialog box-click on service.click on the appropriate service.
Apr 03, 2008 | Epson Stylus C60 InkJet Printer
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
Resetting ink counters on epson c42ux
You can try the other software you can use to reset the counter.
http://www.coldreset.com/modules.php?name=News&file=article&sid=95
Also make sure that on the ssc software, you have selected the correct printer model.
Mar 24, 2008 | Epson Stylus C42UX InkJet Printer
I have had the same problem, my solution was taking a hammer to the stupid thing and buying a lexmark!
Dec 10, 2007 | Epson Stylus C42UX InkJet Printer
To make my Epson printer, model "Epson stylus C42UX" work in India, with Indian ink catridges T038 & T039
This is a tricky one, but there are possibilities.
1. Buy a set of epson C42 cartridges from the cheapest source and keep refilling them - you will need a (very cheap) resetter.
2. Transfer the C42 chip to the C41 cartridge - they are only clipped in place. I don't know if this will work because I only have knowledge of C42 cartridges - the C41 cartridges may be keyed so they wont fit in a C42 cartridge carrier. You may be able to identify a clone manufacturer for which this is possible. You will also need the resetter for this solution.
3. Fit a Continuous ink system (CISS) see for example http://svp.co.uk/products-solo.php?pid=3569&prepg=1
Nov 06, 2007 | Epson Stylus C42+ InkJet Printer
Epson Stylus C42UX InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
