Question about Bosch Refrigerators
I have bought a new Bosch Fridge freezer and the pump seems to be running a lot, the heat exchanger grill at the back of the freezer is warm while the pump is running indicating its trying to cool down. The doors are properly closed and the seal look good, i don't open the doors very long. My old freezer was hardly running in the same location. Any idea ?
  • chip_one Aug 01, 2008
    The Fridge freezer has been in the kitchen for over a month now, i have digital thermometer which has a probe on a lead which i have put inside the fridge or freezer compartment. I can see the temperature getting warmer over a 10 - 20 minute period then the compressor kicks to cool down again. Door hasn't been opened and seals look good. How much would you expect the fridge to loose temp , ambient temp in kitchen is around 22 degress c.
  • 833 Answers
Sounds normal to me. The compressor will run quite a bit until it cools the unit down. This could take a few days. The heat from inside the box has to go somewhere. The coils might be quite hot. If the unit maintains proper temperature...all is probably well. If ice cream is soft, then get a service person in.
Posted on Aug 01, 2008
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
Cold freezer, warm fridge
try and clean the coils under the unit dust builds up and air can't flow over them for heat exchange also make sure the fan is running near the coils
Aug 19, 2012 | Refrigerators
Refrigerator side getting warmer. Freezer seems ok. Recently there has been a lot of things added to the fridge side and it is quite full. I wonder if Something is blocking something but I can't see...
It is all rightt if the heat is just warm . This is so becasue your fridge exchanges heat for the cycle of gas being compressed and released that eventually cools your freezer. earlierr fridges had the coils on the back side which was open but now they are mounted on the sides with glass wool packing. Hence if your freezer and functions seems alright just see that the thermostat is not kept too much and allow the fridge to shut down frequently so that the coils cools by heat dissipation. I hope my advice is helpful Good day
Jun 22, 2010 | Frigidaire FRS23R4A Side by Side...
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer cold but frosted up, Fridge Warm
If the freezer is packed to the top and the air ducts are blocked it can not share the cold air with the refrigerator and it gets warm. If this is the problem, then the next day it should get cool again! let me know.
If you decide you need service!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Bosch classixx frost free fridge freezer
i cannot set the temperature from -12'o to -24'o
Jun 23, 2008 | Refrigerators
Miele Fridge freezer - the freezer temperature indicator shows the temperature to drop from 20 to 10 in under one hour despite the door not being opened. By switching on the super freeze the temperature...
first...Check whether the ventilation gaps
have been covered over or become
dusty.
2. Check whether the metal grille (heat
exchanger) at the back of the
appliance has become too dusty.
It needs good area of circulation and clean coils/grilles.
it makes it hard to cool it down if dirty/dusty. I don't think the oven is doing it cuz operating in a room/outside which is too cold will cause the cooling system to switch
off for too long, causing the freezer
section to become too warm.
My best guess is vents and coils dirty/dusty.
Jan 20, 2018 | Miele Refrigerators
Refrigerators Logo
108 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
