Question about Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card
Just Tried Again
I looked in regedit and I still don't have my upper and lower filter after 3rd try to reinstall XP. I rebooted my comp and it recognized a new software found but when it tries to install the same answer comes out. Failed to install (error 10) also it says sigmatel/wdm not found.....
  • David
    David May 11, 2010
    what computer do you have and what drivers do you need seems like modem driver
    Champion:
  • 208 Answers
Its permissions to registry or system folder.
Posted on Aug 01, 2008
I have a Compaq laptop with a Optiarc DVD RW AD-7560 ATA Device. It will not read a DVD. I get code 19 error. I uninstalled this device. re booted computor. Upon rebooting it tried to reinstall device...
@wagonervboat
If your CD/DVD Drive is missing under My Computer, try the following:
1. Click Start > then type regedit then press enter
2. Double click on HKEY_LOCAL_MACHINE
3. Double click on SYSTEM
4. Double click on CurrentControlSet
5. Double click on Control
6. Double click on Class and look for {4D36E965-E325-11CE-BFC1-08002BE10318} and click on it.
7. On the right side, look for the keys Upper Filter and/or Lower Filter
8. Right click on it, delete it and reboot
Microsoft created this fix when they found out that it's beginning to be a known issue. If this won't work for you, your CD/DVD drive's read lens must have worn out already and you need to replace your ODD.
Good luck.
Sep 06, 2011 | Computers & Internet
My DVD writer is not working at all. in the device manager it shows an error. i tried to reinstall it as recomended by the trouble shoot. would u please help me .
If you oare using a windows based operating system.
On your keyboard hold the windows logo and press the letter R
When the run box comes up type in regedit
go to this key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
delete the upper and lower filters
Reset the computer and check if the cd/dvd drive will now work.
Hope this helps!
Jul 19, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
When i click on my computer to show the drives.my hard drives show but my cd and dvd does not show. windows says that the drivers loaded but cant find the devices. so i shut down to reboot then i pressed...
have you tried changing the lead that is used to connect the drives. Also if you are connecting more than one cd or dvd then try connecting just one to see if they are detected . If they are detected on there own then you have not set the jumpers on the back and they are conflicting over who is master or who is slave. there is three settings on the jumper master slave and cable select
Mar 12, 2011 | Abit Fatal1ty FP-IN9 SLI Motherboard
When i insering dvd it shows nothing or it shows full of free space in the cd drive. I also tried to write files in a dvd contains free space this will not responding. Please Help to solve the...
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or if these fail to resolve the problem
hope this helps
don
Mar 03, 2011 | Compaq Computers & Internet
CD ROM location not found. maybe deleted. How to install again?
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don
Feb 13, 2011 | Computers & Internet
Trying to boot comp to win xp, got message that win32 system file was missing tried using winxp disk and now getting message exiting intel boot agent insert system dis in drive press any key when ready
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppydrives.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 22, 2011 | Toshiba Satellite A10-S100 Notebook
The application failed to initialize properly (0xc000007b). Click Ok to terminate the application." error message in windows xp sp2 for some application.kindly help me how to solve this problem...
your disk drive might not be getting continuos power
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 25, 2010 | Microsoft Windows XP Professional With...
My asus notebook wont allow me to play dvds through my asus dvd-rw
do you have ITunes installed?
if so it puts upper and ;ower filters in the registry that causes issues like that.
if you have itunes installed goto start type regedit
open up registry editor and goto these keys and delete upper and lower filters.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{CE5939AE-EBDE-11D0-B181-0000F8753EC4}
this will remove the upper and lower filters then goto device manager and delete the dvd drive and reboot the computer.
it will detect and reinstall the dvd drive.
Jun 19, 2010 | ASUS Eee 4G Notebook
Cant find e drive need to know how to find and reinstall
HI
If it is regarding the CD/DVD dvrive then follow this:
Please go ahead and click on start > in start search type in device manager {(in vista ) in case of xp right click on my computer > properties > hardware > devicemanager}.
In device manager click on the + sign beside the cd- dvd > then right click on the driver and uninstall it .
Then in start search type in regedit {(for vista ) for xp in run type in regedit}
Look for some thing like
HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
Then on the right hand side look for something like upper and lower filters and delete the upper and lower filters....
Restart the notebook . It will help
Mar 29, 2010 | HP Pavilion dv6000z Notebook
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
