Question about HP Office Equipment & Supplies
Since changing my ink cartidges, each time I turn on my printer, I get the re-alignment page
  • Novice78 Jul 31, 2008
    I was hoping for free help!
    Novelist:
    Scholar:
  • 125 Answers
It's very difficult not knowing what printer and what cartridge. As long as it is doing alignment, it means it is accepting your cartridge. But since it keeps on asking it everytime you turn on the printer, it might be you need to check if the contact points have ink on them as well as the contact pins on the printer, it they are clean then just re-insert the cartridges carefully. If it doesn't work, try one of your old cartridges to see if it will do the re-aligment request or not. If it doesn't then it's most likely the cartridge. If it does then it might be a hardware problem w/ your printer. Hope this helps.
Posted on Aug 01, 2008
Printer will not copy when selecting black ink, page come out blank,will copy page in color but will not print the black sections
either download the hp program for that specific printer from the hp website or.... turn power off unplug press power button to drain all power disconnect from your computer. In your device and hard ware settings delete the printer or uninstall it. Now in this order exactly plug power cord back into printer and power on next plug com cable or usb cable back into computer from printer let your computer install the drivers and programs all over again and when this is done it should be reset now print a test page and enjoy
Apr 12, 2014 | Office Equipment & Supplies
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
Cartridge error code 1203
HI Don,
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
Solution
Use the klennex with a few drops of water to dampen and clean off those contact on the holder and printer may work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
-rate this if it helped you.
Apr 08, 2010 | Dell 962 Photo All-In-One InkJet Printer
Prints alignment page everytime turned on
Did you follow the alignment procedure after changing the ink cartridge? If not complete the alignment.
May 15, 2009 | HP Photosmart C3150 Printer
Cartridge Alignment Won't Work
HP.com has a web page that specifically addresses this type of error with your product:
Ink Carriage Alignment Fails
Hope this works. Post back your results. Good luck.
Oct 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Deskjet D4160
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at thumuvikram@rediffmail.com. I 'll be glad to help you ...
Bye.
Mar 27, 2008 | Apple HP DeskJet 3820 InkJet Printer
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Ben Johnson
