Question about Edirol UA-4FX External Sound System
Lower and Upper filters Gone!!!!.
I followed the directions of microsoft to remove my upper and lower filters for the reason being that it could solve soundcard problem.But now it's worst I tried to reinstall windows xp and it wont restore it.When I run and try to to install SigMate Audio codecs it say error 10.......Please Help!!!!!!!
    Champion:
  • 208 Answers
Sounds like permission issues in the registry or the system folder.
for files try cacls xp reset in google and go to tweakxp website.
for registry you have to right click , permissions and make sure your user name is checked for full access to multiple locations of registry.
Posted on Aug 01, 2008
My dvd player is gone in my computer
Did this just happen recently? Have you recently installed a new software in your computer? because sometimes when you installed a new software that is not compatible with the software installed in your computer conflict may arise and malfunction may follow but no worries there are a lot of trouble shooting steps you can do to fix this issue, you can either do system restore or delete the upper and lower filter in your computer.
To delete upper and lower filter follow the steps below:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
- HKEY_LOCAL_MACHINE
- SYSTEM
- CurrentControlSet
- Control
- Class
- {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
- Upper Filters
- Lower Filters
- Upper Filters.bak
- Lower Filters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
I hope this information will be helpful. Thank you for using FixYa!
Mar 09, 2011 | ASUS Computers & Internet
My Lenovo 3000 G410 Optiarc DVD RW AD-7560A ATA doesn't read dvd or cd anymore... so I can't install Ubuntu for my laptop. can you tell me what is the problem???
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
Your Feedback is greatly appreciated.
Feb 25, 2011 | Sony Optiarc AD-7170S Burner
Hi, i have an asus laptop, the cd player wont play anything. its spinning and sounds as though its about to load in but nothing comes up not even an error!! itunes, realplayer or windows wont pull it...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Click on Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
After deleting the keys, close the registry editor
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 28, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
How to change 2007 dodge 1500 front struts?
Removal & Installation Independent Front Suspension – 2WD Vehicles To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Safely raise and support the vehicle.
  3. Support the lower control arm outboard end.
  4. Remove or disconnect the following:
    • Upper shock absorber nut, retainer and grommet
    • Lower nuts and shock absorber
To Install:
  1. Install or connect the following:
    • Lower retainer and grommet on the shock absorber stud and insert shock absorber through frame bracket hole
    • Lower nuts
      1. Torque to: 25 ft. lbs. (34 Nm)
    • Upper grommet, retainer and new nut (or existing nut with Mopar Lock N Seal or Loctiti 242) on the shock absorber stud
      1. Torque to: 40 ft. lbs. (54 Nm)
  2. Remove support from lower control arm outboard end.
  3. Lower the vehicle.
Independent Front Suspension – 4WD Vehicles To Remove:
  3. Remove tire and wheel assembly.
  4. Support the lower control arm outboard end.
  5. Remove or disconnect the following: dod_ram15_02-04_4wd_shock.gif
    • Upper shock nut with insulator and retainer
    • Lower shock bolt
    • Shock absorber
To Install:
    • Upper part of shock absorber into frame bracket with insulators and retainers and nut
    • Lower part of shock absorber into lower control arm with the bolt
      1. Torque to: 100 ft. lbs. (135 Nm)
  2. Remove support from lower control arm.
  3. Install tire and wheel assembly.
  4. Lower the vehicle.
Link/Coil Front Suspension To Remove:
  2. Remove or disconnect the following:
    • Nut, retainer, and grommet from upper stud in engine compartment dod_ram15_02-04_shock.gif
    • Nuts from upper shock bracket
  3. Lower bolt from axle bracket and shock absorber from engine compartment
To Install:
  1. Position lower retainer and grommet on upper stud and insert the shock through the spring from the engine compartment.
  2. Install or connect the following:
    • Lower bolt
    • Upper shock bracket and nuts
      1. Torque to: 55 ft. lbs. (75 Nm)
    • Upper grommet, retainer and upper shock absorber nut
      1. Torque to: 35 ft. lbs. (47 Nm)
Jul 22, 2010 | 2007 Dodge Ram Truck
My cd drive disappeared off of the my computer screen. what can i do to get it back?
Hi, Check the device manager. Then try to uninstall then reinstall it. Restart the notebook and try to test the optical drive. Just try any cd. If that doesnt work delete the lower and upper filters from the registry editor. See the link for instructions:
http://support.microsoft.com/kb/314060
Dont do the fixit. Just follow the deleting the upper and lower filters.
Mar 05, 2010 | HP Pavilion dv6000z Notebook
Changing registry settings
access registry editor by typing regedit in run , then Press Ctrl+F and then find menu will come, there enter the upper filters and lower filters. Now u can get the results with the value having lower or upper filters.
Oct 25, 2009 | Microsoft Windows XP Professional
Optiarc DVD RW AD-7561A This device cannot start. (Code 10)
I beleive that this code is being displayed under the Device Status in the Properties window of the DVD Drive in Device Manager.
If it is so, you need to do some modifications with the Registry to resolve the issue and I am sure that the issue will be resolved with this.
However, since you had not specified the Operating System which is installed in the Notebook is Vista or XP.
However, I am providing the links which includes the steps for both Vista and XP to edit the registry to resolve the issue with Error Code 10 with the DVD Drive in your Notebook.
Removing Upper and Lower Filter in XP :
You need to perform the steps listed under Advanced Troubleshooting to delete the Upper and Lower filters.
Removing Upper and Lower Filter in Vista :
http://support.microsoft.com/kb/929461/en-us
You need to perform the steps listed under Resolution in the link above.
You may not find both the Upper and Lower filters according to the instructions links provided above.
Delete the ones among the Upper filter or Lower filter or both which you find in the locations mentioned.
This should solve the issue...
Oct 25, 2008 | HP Pavilion dv6000z Notebook
My COMPUTER WON'T READ CD TO SET UP PRINTER. COMPUTER WAS REMAPED
go to my computer and see if the CD is listed there or not. In case the CD drive is not listed check in the device manager. Go to registry editor by yping regedit from start-run.
Follow the directions here to delete the upper and lower filter values in the registry. Then remove the device from the Device Manager and reboot:
http://support.microsoft.com/default.aspx?scid=314060
http://support.microsoft.com/kb/320553/
Oct 05, 2008 | Lexmark Office Equipment & Supplies
How to delet value data from upper lower filters of the key
The easiest way to remove the filters is to use the tool that Microsoft supplies at this link. http://support.microsoft.com/kb/314060
Jul 02, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Edirol UA-4FX External Sound System Logo
200 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
