Question about Samsung Office Equipment & Supplies
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other sources though
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,362 Answers
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Posted on Jul 31, 2008
How to receive a fax--i can send a fax but not receive
Not sure what this has to do with a 7630 phone, but you forgot to mention if the fax machine rings when a call comes in and if it's set up to answer on incoming calls, or is it just not ringing at all.
If the call goes out, dial 800-444-4444 and double check the line the fax machine is on. Make sure you're not dialing "9" to get an outside line, and if it happens to be truly on a TDA phone system, then the jack you're using has to be programmed to ring.
Carl
Jun 23, 2011 | Panasonic KX-T7630 Corded Phone
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Keep receiving duplicate faxes
Some Brother fax machines are programmed incorrectly so they do not acknowledge receiving the last page of a document. The sender doesn't know you got it, and will resend.
It's harsh advice, but the only solution is to buy a different brand.
May 07, 2010 | Brother IntelliFAX 4100 Laser Fax
Can't receive a fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
Jan 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Oct 03, 2008 | Office Equipment & Supplies
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
204 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
