Question about Samsung YP-U3 MP3 Player
Will not turn on
Player died and will not turn on. It was fully charged. then when i plug it into the computer thinking i was wrong with it being charged. the computer will not acknowledge it is there
  • 3 more comments
  • pasindumanis Aug 19, 2008
    whean i was plug it it says ''usb device not recognizised'' and it did't on
  • AJ Slater Aug 21, 2008
    my samsung yp-3u was in my drawer at home for 3 weeks. I plugged it in to my PC to charge it and y PC doesn't know it is there! It is as dead as a door nail. What can I do, it is only 9 months old?
  • Anonymous Aug 22, 2008
    my samsung ypu3 has no charger how culd it be charge
  • Odoyi Mary Aug 27, 2008
    The player was loaded with alot of songs but when ever i skipped to aparticular song,it would show power failure and then turn itself off. I erase some files from it but it continued doing the same thing.When i forwarded the song to the end, it just blacked out and now it cannot power and even the computer cannot recognise it.
  • chipineitor Sep 01, 2008
    I was listening to the mp3 files, when suddenly, it turned itsefl off, and it kept the led light on (and it stayed on), until the battery went out of charge. During the time of the still light, i tried to turn it on, but it never responded, i tried to plug it into de pc, but the pc never recognized that there was a usb connected, y tried to reset (restart or reboot) the system by putting the hold button in hold and pressing at the same time the play/on/off and user buttons for a while, but it never responded... is there another way to restart o reset the player?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Aug 14, 2008
Eclipse cld mp3 player wont turn on unless plugged into computer
Go in your menu and change the settings to manuel operation
Dec 25, 2012 | Audio Players & Recorders
I have a Sweex Vici MP4 player i think the code for it is MP156 - i cannot turn it on - it only turns on when plugged into my computer but it is fully charged so i dont understand what is going...
Full charge player's battery. Now you must set the power switch to ON position and next hold on the play-pause button for 2-3 seconds. Repeat this step for soft-OFF.
Petr
Dec 24, 2010 | Audio Players & Recorders
My ematic mp3 player will not turn on and it is fully charged. I had realized i overcharged it and it wouldn't turn on so i just clicked on reset and now it won't turn on, even when i plug it into the...
You shouldn"t be able to over charge it.unless there is something wrong with the unit.i had a simular problem with my Zune.it was fully charged but as soon as i unplug it it would not power on,it would only work when plugged in,i had it replaced under warrenty.call your manufacturer.
May 07, 2010 | Beond Ematic EM304CAMB Digital Media...
Charges slow and battery dies quickly
you most likely "over charged" your MP3 player...
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Ipod will fully charge but only lasts a short time. whats wrong?
My little brother gave me his ipod shuffle for the same reason, saying the battery was dying and would only play for half an hour after a full night's charge. However, I went ahead and gave it a shot anyway and it always lasts for several hours (long enough that it's never died, so I don't know an actual time).
Anyway, it turned out to be a usb hardware problem. His old computer wasn't built to charge via usb, so the ipod would take what little it could and flop five songs later. I don't know what kind of hardware you're running, but perhaps you could try plugging it into a different computer and seeing if that chnges things?
I would also recommend looking into wall chargers, if that is the case. Otherwise the convenience factor kinda goes out the window.
DigitalGrampa@Gmail.com
Mar 28, 2009 | Apple iPod nano
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-U3 MP3 Player Logo
294 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
