Question about Refrigerators
Feezer keeps defrosting itself - Refrigerators
  • 120 Answers
Try adjusting the thermostat (freezer setting). Crank it from lowest to highest to lowest a few times, and then leave it set on the lowest setting. That may get something unstuck. You could try putting a little light (low viscosity) silicone oil on the working parts of the thermostat. Silicone oil doesn't get thick at low temperatures.
Posted on Jul 31, 2008
Describe your (PSS26MSRSIDE by Side Refrigerator ProblemTHE BACK OF MY FEEZER KEEPS FROSTING UP IT HAS ALUMINUM COILS. I CLEAN THE DRAIN HOLE. BUT IT KEEPS FROZTING UP EVERY COUPLE OF DAY, I HAVE IT ON THE...
The most likely reason the evaporator coils are freezing up are because the=> WR51X10042 Defrost Heater is defective or burned out. Click here for your PSS26MSRSS=> for a photo location of the WR51X10042 Defrost Heater in that photo location number 230 is the WR51X10042 Defrost Heater While inside the evaporator compartment you should also change the=> WR50X10068 Defrost Thermostat and it is listed as location 240. Click here for the PSS26MSRSS Freezer Components locations. On both of these part pages are a movie tutorial of how to test and replace these parts. Here is another tutorial from You-Tube=> HERE Hope this was helpful and should you have any questions I will be here to assist you., Thanks, Sea Breeze
Sep 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer keeps getting frost in the back. When this happens, all the temps in my feezer and fridge go up. Fridge is at about 45 and freezer is at 4. This is the second time in three weeks. What should I...
some component of the automatic defrost system is defective watch this video :::pay special attention to the part about the defrost thermostat since itthe most likely cause with frost built up in the freezer the defrost t-stat should have continunity (the circuit to it should be closed)
here is the link for the video,copy and paste it into your browser if it doesnt link automatically.....http://youtu.be/TnRKj7_BtNw
Jul 20, 2011 | GE Profile Arctica Stainless Steel Top...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My feezer is not defrosting properly, I ohmed def heater
I noticed that you left the most likely part out. Defrost Timer=> 215846602 Click Here=> FRT17B3AW5 User Manual on page 17 letter E Click Here=> FRT17B3AW5 Wiring Diagram some models had Adaptive Defrost there but I think yours has the defrost timer. If this was helpful please rate me. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 20, 2010 | Refrigerators
Feezer COLD food compartment not cooling. It
the heat element or the thermostat IN YOUR FREEZER PART need to be check...they might went bad and when you defrost the unit it is working fine but only for period of time....:(
Dec 30, 2009 | Amana Easy Reach Plus ABL2037FESL...
Slimline feezer 8504 126 15011 works intermittantly
why do you need a freezer if you only have ice
Nov 07, 2009 | Washing Machines
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
The freezer half is not working
sounds like the defrost timer is stuck to me
call the fridge man or bur a new fridge
parts should be arround 50 plus 50 to install
but call and check first
Jul 25, 2009 | Refrigerators
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
