My PC stopped booting up yesterday. When turning it on, you can hear everything powering up (fans working, hd's going, lights on case and mobo etc) - but after 3-6 seconds it turns itself off. After checking all power connections, and trial and error - I established that by removing my GTX 7800 graphics PCI-E card - the system powers up correctly (although i obviously can't see whats going on). When putting the card back in and starting up - the same thing happens and it shuts down almost immediately. This also happens without the gfx card power cable connected. This would indicate to me that it isn't a PSU issue? So I'm now assuming it's either a gfx card issue, or the PCI-E mobo connection. Any ideas which it is more likely to be? (I don't at this stage have a spare PCI-E card to test. Thanks.
  • bluejazz9 Aug 31, 2008
    My Dell Dimension 8400 dektop has been shutting itself down several seconds after powering up the system. This doesn't happen every time, but it is becoming more frequent lately. Also, about a month ago, I began receiving notices (black screen, white font) saying the the battery was low and that may cause data loss. After appearing several times, the notices disappeared.
    A friend suggested I change the lithium battery; but I hesitate to do so until I get some expert feedback. Will you please help me figure out what to do?
    Thanks.
    michael
    bluejazz9@earthlink.net
    Novelist:
  • 148 Answers
Greetings My name is Mark and I will be glad to assist you. The problem you are having is the compatibility of the Video card and the amount of high memory you have installed. Go back to when the problem started, (new software hardware,Etc,) If this is not the issue you have a card failure and it needs to be replaced. By installing a video card it will use high ram memory in most cases with a graphics card the processor needs to be of greater speed then then video card it is looking at. The key is to maximize you ram and make sure you have proper ventilation for the ram as well as the video card. Heat will cause failure and slow performance. Take care
Be mucho blessed,
Mark
Posted on Aug 10, 2008
  • 57 Answers
If your motherboard supports SLI, you can most likely eliminate the port the video card is plugged into by plugging it into a different port. Based on my experience the most likely cause is the video card, especially since there are probably other components on the board that share the same bus as the video card. Look carefully however at the pins on the card. I had a "remanufactured" motherboard fry two ram chips and a video card the first time i turned it on.
Posted on Aug 02, 2008
    Champion:
  • 209 Answers
As you have said you are using the pcie video card, in order to determine if this is damage or not then remove this then use the on board video card. once this boots up then the problem is your pcie video card. this might not properly set up to the slot or it has a defect. try to clean this first with a pencil eraser to its contact points(bronze color) then wipe it with clean cloth make sure that no eraser residues left to prevent short circuit.
Posted on Aug 01, 2008
    Novelist:
    Scholar:
  • 70 Answers
Is there a fan on the video card? It could be that the fan on the card has quit working. Most systems will shut down if the chip on the card gets hot. Try to rotate the fan with your finger. Is it hard to rotate or stuck all together. These tiny fans are very inexpensive and since they fail so often they can be found at many office supply retailers.
You may find that it is one of the other fans that is not working too. When you remove the card or the cable the system will not consume as much power. Look also at the main processor chip fan and the power supply fan.
  • 3,940 Answers
Replace the PCI-E video card. If removing the card causes the system to POST, then it is very likely the card is the fault.
The only concern is CASCADE failure. This occurs when the expansion card damages the slot it is installed in, then when the card is replaced, the slot damages the new card, causing a chain of failures.
You still have a pretty good chance that replacing the video card will resolve without further expense.
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
How to fix a motherboard that does not turn on at all.
Make sure there is power at the outlet, surge suppressor, power strip. Be sure any connected UPS is on. Try again.
Remove any recently installed hardware and go for boot. If the PC boots, check to make sure that the new hardware does not overload the old power supply - if it does, replace with a higher capacity power supply and go for boot.
Open the PC. Look for indication of power - LEDs, fan, etc. Replace the power cord between the outlet and computer if one is available, and go for boot.
If possible, obtain a power supply tester to determine if the power supply has failed. Replace any failed Power Supply and go for boot.
Disconnect power. Disconnect all non-required cables and accessories. Leave only the power and data cables for power supply, boot drive, video card, mouse, memory and keyboard connected - everything else should be removed (with the exception of the small cables that go to the MoBo headers for LEDs, and switches on the case). Everything means both data and power cables. All controller cards should be removed as well unless using on-board or built-in controllers. Reconnect power and try for Boot.
Add devices, cables, etc one at a time to determine which is causing the fault. A PC that boots and shuts down shortly after could be an indication of overheating / over load. Clean dirt & dust from case, ventilation slots, etc. Make sure all fans spin freely - replace any that do not.
Those are some things to start working on.. hopefully, you'll find the problem and not have to go further. Good luck!
Aug 25, 2010 | Asrock 775VM800 Motherboard
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
PC will not power up. No fans, lights, anything.
Have you tried a different power cord? (longshot, I know, but it is one of the variables that you don't mention)
Have you tried a different A/C outlet?
Dec 22, 2009 | Computers & Internet
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
Video card upgrade
Can you try your old card? does your card have a 6 pin connector on it for power? Does your power supply have a 6 pin connector for video card power?
Lou
Aug 28, 2008 | Sony VAIO VGC-RA810G PC Desktop
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
