Computer wont turn on i tried to replace the hard drive but it wont turn on
  • 43 Answers
Is it completely dead?If so,you probably need a power supply
Posted on Aug 01, 2008
  • 81 Answers
If you turn on the pc and the power fan turn on but your pc did not. turn it off again and clean the memory and the memory socket maybe it is full of dust. blow the dust with air blower and place the memory back in place. try to test is again
Posted on Aug 03, 2008
Replace poer supply
Posted on Aug 02, 2008
Do you have lights and or power to the motherboard?? do you get any beeps when you 1st turn pc on ?? is there no picture or signal . then it's your CPU
  • 26 Answers
Totally computer black even u turn the power on? means u didnt see any messages on your windows?... do this tip for you dear,
check your connections, as what other solutions advice to you. connections such as, the plug of your computer at the back of it, make sure it is plug fit to the outlet, or if your using AVR check it. all connections of your PC - CPU - AVR strictly check it ALL. Better, unplug it then plug it again to the outlet, to make sure its connected better.
Hope it help you.
thank you.
    Problem Solver:
  • 11 Answers
Check the power connections and try with genuine drive
    Problem Solver:
  • 4 Answers
Have you tried booting with a Live CD ? This would eliminate OS as the problem....do you get any sytem messages ????
Compac s7300cl wont turn on
Ok it seems *********** board may be dead. However, you can take out the hard drive and place it in an external hard drive storage unit/box
and plug this into any computer, and WALAH! You have another
drive letter, which is your old hard externally. You may now get your pics. You can access them via any photo software; however, you need to make sure that you save them on another drive letter, and or folder. Not the external drive Letter it may be called D or E.
Sep 17, 2012 | Computers & Internet
Wont boot up
Your hard drive needs replacing. You have lost the boot sector on the hard drive.
Nov 19, 2011 | IBM ThinkPad T40 2373 Notebook
The monitor wont turn on at all,even rebooted the original disk still wont turn on,bought it in 2009 but cant find any of the paper work for the warrenty, so dont know what to do, its just not turning on.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Compaq Q2009 Monitor
My HP G6000 Notebook PC, wont turn on. the AC charger adapter lite powers on when connected but wont turn on the pc. three days later my computer still wont turn on, but now the bottom three lite...
It is a probably a short in your hard drive or power supply to the hard drive. Honestly may be cheaper to replace the computer if it is a power supply short, laptop internal components are expensive to repair.
Sep 21, 2010 | HP Computers & Internet
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
Reseat the hard drive
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Feb 03, 2009 | Dell Inspiron 1525 Notebook
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Computer wont recognize usb drive
try to use another connector! and try connecting it to other USB ports!
Dec 06, 2007 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
