Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
MY FOUR STROKE MOTOR CYCLE IS BLOWING LOTS OF BLUE SMOKE,THE PISTON AND RINGS ARE STILL FINE AND ARE AIR TIGHT WHAT IS THE PROBLEM PLEASE
Blue smoke is oil, black smoke is fuel! go to harbor freight and buy a cylinder leak down tester as this will give a proper diagnosis between the rings or valves. do not expect 100% on ring seal as even race cars can not do that but any thing below 80% is suspect. the valve seals can be changed without pulling heads by appling air pressure on the cylinder on compression stroke and the use of a small hand held spring compressor, harbor freight also. make sure you c/c vent is working or it will build c/c pressure and move oil anywhere it can get out bad rings or broken rings means a tear down is necessary.
Posted on Aug 13, 2008
    Genius:
  • 2,028 Answers
Your air fuel ratio needs to be adjusted. You're getting to much gas and not enough air.
Posted on Aug 06, 2008
05 Troy built suoer bronco it has a 19 hp engine.
white smoke usually indicates excess oil consumption. make sure you can turn motor over by hand you should feel resistance when the piston is on the compression stroke ensure ignition is off to do this test. no ressistance would indicate low compression and possible cracked or broken piston ring or. worn piston rings. Test by putting a small amount of oil into combustion chamber the oil will temporarily help seal off the piston rings and result in more compression indicating worn rings.also oil filler breather cap blow by would indicate this as well hope this helps.
Sep 04, 2014 | Garden
Rebuilt and still smoking
how much smoke because 2 stroke engines do blow quite a lot of smoke it is normal as you mix oil with fuel to lube the cylinder walls and the piston
Jan 24, 2014 | 2008 Husqvarna CR 125
Motor is smoking in my '02 diamante, is it the gasket?
Smoke diagnostic is made by colour.
If u mean pistons head gasket,yes,it can smoke.
White (clear) water vapor.Ceck coolant level.Ceck engine oil colour by dipstick.
Black:runs rech on fuel (fuel filter/fuel lines/fuel mixture...)
Blue (whity):worn pistons rings.
Chears.
Tips:
Whity smoke before warming may be natural on cilli mornings with lot of compressure the engines just blows vapors.
Old oil/fuel residues in the exhaust tubing may blow smoke after heating the engine ,must track problem (...).
Black smoke on hitting the acceleration to the floor may be natural (overcharged) avoid sport driving style.
Sep 29, 2013 | 2002 Mitsubishi Diamante
My 2008 sym jet euro 50 x smokes a lot and wont start when left an hour or so
Is It A 2-Stroke Or A 4-Stroke. It Could Be A Fuel Mix Problem Or A Piston Ring Problem. 2-Stroke (Mix) 4-Stroke (Rings)
Jul 31, 2012 | 2007 Sym Jet Euro X 50
Fixing piston rings motorcycle
Piston rings are important to get the engine running properly. To replace them you will need to get at the pistons. As you don't say what bike you have I can't be more specific, With a 2 stroke it is easy, a four stroke is a bit more involved. Incidentally I doubt if the engine has NO piston rings. But they may be worn or broken. And in either case the bits from them are in the crankcase somewhere, this is not good- I would get it seen to as soon as possible.
Feb 12, 2012 | Suzuki Motorcycles
Are bike is having a little smoke coming from the exhust pipe we think it might be the antifreez we just moved from florida our manual is packed away just need alittle advice
is it blue coming from the exhaust
is it a 2 stroke if its a 2 stroke blowing blue smoke its quite normal if its blowing to much your rings might need replacing keep an eye on the ((oil level))
if its a 4 stroke and its blowing blue smoke from the exhaust keep an eye on the ((oil level)) the rings might need replacing if its burning lots of oil and blowing blue smoke your rings do need replcing
hope this helps
Mar 02, 2011 | Geovision GV-650 BNC (GV6504) Video...
I just bought an 03 RM250 and the dude told me that he had just rebuilt it. I picked it up at night so I didnt notice the smoke then. When it runs man it pours blue/white smoke terrible. I thank it may...
Is this bike a two stroke or four stroke.Meaning do you mix oil n gas,or dose it run on straight gas .If this a two stroke,its normal to blow blue smoke,but not that bad.Sounds like the person before you put to much oil in gas or piston rings are shot.There are exact oil to gas ratios you must follow with a two stroke engine.If you dont, you can have all kinds of problems.
Feb 08, 2011 | 2003 Suzuki RM 250
My 2006 ktm 250 sx-f smokes blue when i pull away
Is this a 4 or 2-stroke?
4-stroke = bad valve seals of piston rings
2-stroke = oil/gas ratio too 'oily' OR air filter clogged.
Dec 14, 2009 | 2006 KTM 250 SX-F
My crf230f 07, is smoking
Your piston rings are letting a bit of oil get into the top end. No big worry or concern. As time goes by the smoke may increase or it may not. If it gets offensive then you will need new rings, Possibly a new piston and possibly have the cylinder bored out, ( some cylinders can not be bored ). Just check the oil and keep it at the proper level. Change oil three to four times a year. Not changing the oil is probably what has caused the problem. Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives.
May 27, 2009 | 2005 Honda CRF 230 F
Smoke alot
sounds like the bike is in need of new piston rings especially if that much oil is blowing on such a newer bike. if the crankcase is not overfilled, then focus on rings especially if the sparkplug is oily too.
Feb 03, 2009 | 2004 Suzuki RM 125
Lands Phones Logo
123 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
