My printer spooler stops working and I do not know what to do, I turn it on but it cuts out again
    Genius:
  • 2,785 Answers
Just try by reinstalling the pritner
Posted on Jul 31, 2008
Printer stop printing
It could be the Print Spooler service on your computer that's not properly working. Try these steps to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Mar 11, 2012 | Lexmark X5470 All-In-One InkJet Printer
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Printer refuses to print. Shows message 5100. Nothing in printer manual shows how to remedy fault. Unable to find anything on website to fix it.
Hi
I believe the print spooler had stoped and needs to restart again. Please try this solution
Go to START MENU
Choose Command prompt, right click and run as administrator ( Fow window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
If it does not help you, please let me know to give more advise. Regards
Mar 03, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
HP LaserJet P2015dn Printer won't print from vista computer. If i stop and start the spooler it prints. I have another printer and I don't have to stop & start the spooler for it to print
Try to Create a new account using your Administrator account and then try to print from there. If it works perfect Otherwise ..!
1. Start, Run and type cmd hit enter
2. Type msiexec /unregister hit space and press Enter
3. Type msiexec /regserver (note the space) and press Enter
Now restart the computer. And Restart the Print spooler service.
Click on start--> run--> type cmd hit enter-->
on the black window --> type net stop spooler hit enter--> again type net start spooler hit enter.
Each time it should say successfull stop or start.
Now try to print. If still does not work.
Check the port of the printer. ( start-->run--> type control printers hit enter-->right click on HP LaserJet P2015dn Printer series--> choose properties--> on the top--> choose the TAB--> Port-->now check the port ---> it should USB001 port if its a cable connection--> if wireless it should show HP ip address .
Make sure this is right and then try printing. It should work .
Let me know if it works.
May 07, 2010 | HP LaserJet P2015dn Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
Lexmark X1180 won`t install on new vista laptop
Okay this is a easy problem, the printer spooler service is turned off, just turn it on, and try to install it again, should work if not let me know.
press start and then run
OR
hold down windows key and press r
in run menu type in: services.msc
and press ok or enter
in services, you need to find printer spooler or spooler, right click on it and select properties.
make sure start up type is automatic, then press on start. Apply ok, close window , make sure the service status is running, press F5 to refresh the page.
try installing it now.
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
82 people viewed this question
jasbo
jasbo
