Question about Canon PowerShot S2 IS Digital Camera
CANON IR2022I PRINTER
GOOD DAY,
A NEW CANON PRINTER HAS BEEN INSTALLED AT OUR COMPANY. THE PROBLEM IS THAT IT DOES NOT PRINT OUT THE RECEIVED FAXES.
  • 1,219 Answers
Do you have fax server?There could be problems with it.
Are you directly connected to tel. line with copier?
Try to recive faxex from different numbers and see wats going on
Posted on Jun 16, 2010
How to print from memory laser 710 canon
load white paper and just press the stop button located in the panel, it will print all received documents
Apr 30, 2014 | Canon LaserCLASS Fax 710 Printer
I need service manual for canon Ir2022i
hello friend, you can find the canon iR2022i service manual in below link:
Canon iR2022 service manual:
http://goo.gl/FDaoZk
thanks
Jun 04, 2012 | Canon iR 2022i Printer
RECEIVED IN MEMORY RECOMENDED NEW BCRT
Hi, I have figured out how to manually print it from memory, but it's a real pain after a while. Is there a way for it to print the faxes automatically instead of having to go to:
Menu>Memory Reference>Print Memory List>Ok
then...
Menu>Memory Reference>Print Document> *enter TX/RX* > Ok
Problem has solved.
Good Luck
Feb 14, 2011 | Canon PIXMA MX310 All-In-One Printer
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Good morning i cant sent fax is telling me memory full
May be there are faxes which have been received and have been recorded into memory.
Print the faxes and everything will get back to normal.
Mar 10, 2010 | Canon PIXMA MX310 All-In-One Printer
We would like to print a journal of received faxes for the last month?
it only keeps the last 60 transactions in memory!So if u recieved and sent more than 60 a day it wont be able to print the last month's faxes!
Jan 05, 2010 | Canon L120 Fax Laser Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP190 all-in-one will copy offline and scan online however, when attempting to print online, status shows as 'error-printing'. have checked cables & power, cannot print from print command....
this sounds like a virus any ways, make sure u have a very good antivirus, remove and reinstall the printer with the driver but first go to the printer delete all the printers installed manually i.e after uninstalling the printer and its still showing the printer at printer and faxes, then reinstall it.
Jul 22, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Faxes received in memory but are not printing out
make sure that your canon is your default printer and usb cable is connected.
May 29, 2009 | Office Equipment & Supplies
CANON iR2022i reports Error 000007 on start up
To solve this you can change the fixing film, if you do not know how call service
Mar 24, 2009 | Canon iR 2022i Printer
Canon PowerShot S2 IS Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
